Finished Blanket Chest
Larry Clinton At Frankfort (Central)., Indiana
>I finally finished my DIL's blanket chest. It is made from solid White oak with a 3/4" cedar lining. The bottom is 3/4" oak with a 1/4" thick cedar top, glued in a line along the center only. I made the chest using all M&T construction, except the bottom supports are doweled in location (floor is floating - doweled only in the center at the ends) Finish is Minwax oil based stain, top coated with 3 coats of spray lacquer, first two gloss, last one satin. Then I rubbed it out with 4/0 steel wool & wax. The only metal in the chest is the plaque, hinges, stop chain & screws for those items.
Re: Finished Blanket Chest
Re: Finished Blanket Chest - open
Re: Finished Blanket Chest - end view
Re: Finished Blanket Chest - plaque
>My son and DIL wanted to install a plaque on the chest - so he purchased it and I installed it before delivery
Well, Ain't That The Cat's Meow!
>Larry,
That is just plain gorgeous. Except it certainly isn't plain. It looks beautiful and I bet it is solid enough to head for should a twister head your way. (God Forbid). I never would have thought about interior raised cedar panel presentation. That is neat. Nice finish, too.
George
Jason Roehl in Lafayette, IN
I agree!
>Looks great, Larry! I'm just wondering what you used those bolt cutters for--the raised panels or the rails and stiles? That must have been tricky! ;^)
Jason
Really classy, Larry!
>That is definitely an heirloom, Larry. Your daughter-in-law will be delighted with your beautiful workmanship for many years to come. There is a lot of thought and careful workmanship there, and it shows.
Thanks for posting these shots.
Re: Nice chest!
>Did you consider making a tray insert (or whatever you call them)?
I like the panels (inside and out).
Halsey
>Outstanding chest, Any idea how long it took to make? Halsey
>Thanks for the response, I spent WAY too long making this. Actually had it in the shop for almost a year (some other projects took priority). If I had worked steady I probably had about a couple hundred hours in it. I replaced some boards 2 or three times during dry fitting as I didn't like the match etc.
Re: Nice chest!
>I did, but my DIL kind of knew what she wanted - so it is made to her specs. Thanks for the kudos.
Re: Thanks Ellis
>I really did spend a lot of time on it. My DIL and son both are quite happy with it. Not sure about their two boys - they carried it to the upstairs bedroom!
Re: Well, Ain't That The Cat's Meow!
>Thanks Colonel, I am pretty happy with the way it turned out. I do know I will never make the joints in the ends the same again. I routed a groove in the end boards so the front and back are inset about 1/8" then cut the through mortise and tenons - It didn't leave .010" for errors (and I usually make that much at least. It is real solid but a mite (no a whole lot too heavy) for this style chest.
Re: I agree!
>Thanks for the compliment Jason. As for the bolt cutter, I needed to remove a lock for my sister (storage shed with a lost key) so I bought the "master key" from Harbour Freight. Hadn't had a chance to put them away fore I took the snapshots of the chest.
From a long-ago moving grunt...
>For about a month one summer after HS, I worked as a laborer for a moving company. 6' 140 lbs soaking wet. The idea was that one guy could move most anything, two could move anything. On top of that, I've moved a number of times myself since, helped many friends move over the years, plus have to move furniture all the time as a painter. I would much rather move something that is heavy but solidly built than a lot of the lightweight particle-board-and-laminate garbage that is sold masquerading as furniture nowadays. That stuff is almost impossible to move without doing at least some minor damage, and the risk is very high to do major. Tell your grandsons to appreciate that they got to carry fine furniture. ;^)
Jason
