Quoins- a useful item I wish we could get!
Steve Kreitler
>I check this blog every week- I get probably %20 of the items right, but had no idea what these were-
http://pzphotosans234n.blogspot.com/
scroll down to numbers 1316 and 1317- those look like useful items for woodworkers!
Here's the link for the main page-
www.puzzlephotos.blogspot.com
Re: Quoins- a useful item I wish we could get!
Richard Jones
>New one on me, a quoin (to me) is an architectural feature on brick corners...............
Rich (learning something new, one headache at a time) in VA
Are we speaking of cauls?
Forrest Addy
>As was said quoins are archetectural details etc or, in the days of muszzle loading cannon, a wedge used to adjust elevation.
Are we speaking of cauls? Cauls are pretty simple really - just a couple of boards with a little curve in them used as claing aids.
I have some made of maple that took a set after I'd dressed them. The long ones (about 6 ft I have three pair) are full dimension 2 x 4 have about 3/8 curve along to 4" dimension. And the shorter ones (2 pair) about 1/8" in 32". The curves match pretty well so that if the convex sides are placed together and the ends clamped the mated joint is very straight.
They come -n very handy to ensure glue-ups of table tops come out flat. Pipe clamp the glue up to ensure the joints are pulled together then sandwich the glue-up between pairs of cauls to hold the assemble flat until the glue cures.
You can get fancy or casual but the end result is (with a little care) is superior clamping while the glue cures.
A couple of construction grade 2 x 4's seleceted for their curve works as well as custom made ones of hardwood. Mine happen to be maple because there's lots of it in my neck of the woods and I used it for secondary wood. I used to keep 2M bf in my stash so it's no surprise that off cuts, rippings, and defective hunks feature in my shop built stuff.
Re: Quoins- a useful item I wish we could get! *LINK*
Steve Kreitler
>I didn't post the link in the right manner- it should appear below.
These quoins are metal wedges that were used to secure trays of type.
They have gearlike teeth on the sides, and are tightened with a large key (also pictured on the linked page). They look to me like they would be very handy, and would probably be pretty easy to manufacture, say in filled fiberglass.
Very similar to . . .
steve mackay
>the blocks from a machinist's set-up kit. I had a set when I was working a CMM. Also comes with all kinds of bolts (that screw into the machine bed or platform), clamping doo-dads and blocks. Most machinist's and industrial suppliers carry the kits. You can manage to secure almost anything of any shape with whats in them.
calvin In Irmo, SC
>The description for quoins is correct. The were used to lock type-set pages in frames called "chases" which then were placed in the printing press--both newspaper web presses, and smaller job sized presses. Used them many times when I was a "printers devil" during my high school years--late 1940's. A similar effect can be achieved by using tapered wedges in opposing directions for woodworking.
