New Stereo Cabinet (First project post)
Jake Dahn (so MN)
>Hi all,
Been woodworking for a couple of years, and lurking here for about the same. Thought I would post a recently completed project. I aim for one larger project completed a year....
Since an addition to our family (first son 1&1/2 yrs ago) the need arose for some way to keep the little hands off of the electronics. My first suggestion of "just keep him away from it" was an exercise in futility. So this is the result.
Maple, clear coated with wipe on poly. Carcass is 1" thick by 22" wide by 23" deep and 39" tall. The base assy is 6" tall. Dimensions were made to fit the space and components, not to a golden rectangle
I forgot to take picts before sticking in into place....so they are less than optimal.
As Always, I try attempt something new for each project. This forces me to learn a new skill. It even comes out successful sometimes. This project "first" was inset doors. The turned out pretty well for a first attempt.
Since I use this forum to learn, I will post some of the errors I made on this so others don't have to repeat them.
1) Make sure your glue up table is flat. My main bench was full of clutter so I glued up the main carcass on my table saw out feed table.....which I thought was flat...but wasn't. Trying to unwarp 1" think maple doesn't work...the whole assy rocked a fat 1/16� and had a slight twist in it.
2) When sanding, make sure you didn't pick up any prior grits. After applying the second coat of poly, I noticed the tell tale swirl marks from the random orbit....I thought I had checked it over well, but maple really hides then. Luckily they were on the inside of the door.
3) After a prior blanket chest I found out how important grain matching is....You be the judge on this piece.
4) Blum adjustable hinges are great for being able to fine tune the fit of a door with a critical reveal.
5) Even if you think there is nothing under the towel sitting on your bench that you plan on flipping the completely finished carcass over on...check there are screws under it that will seriously mar the top of the case.....
6) Put handles on it before it leaves the shop....we really wanted it in place at the time to keep little hands away....Any suggestions on handles?
Any criticism would be appreciated. I have very thick skin and am always my harshest critic....
One thing I noticed is that the door frames appear a bit heavy. Next time I would make them at least 1/2 in narrower.
Thanks for the time to read this very long post.
Jake
