New Table Saw Motor
New Table Saw Motor
New Table Saw Motor
Steve Woodall
>I am thinking of replacing the motor on my Jet Super Saw. It has a 1 3/4 hp motor now. It just kills me that I have this big ole saw that I paid a pretty penny for and can't rip a 2x4 without tripping the reset button.
I am thinking of going up to a 3 hp Leeson, Dayton or Baldor.
Do you think this saw would hold up to the strain of a 5 hp motor?
Does the motor have to be TEFC?
I have found a couple of motors on eBay that are the right size and have the right shaft, but say they are compresser duty motors. Would they work?
Thanks for you input,
Steve
Re: New Table Saw Motor
Rick W------WebKitFormBoundaryLAS+gJXDtwvtBHB2
>Why is your present motor tripping the breaker? Are you running it on 110 or 220 volts?
If you're trying to run it on 110, you are probably pulling too many amps for your breaker. If you can switch it over to 220 volts, you'll pull fewer amps and solve that problem.
If that's not the problem, any motor of similar frame size,rotation, and HP will probably work.
Rick W
Fred Davis
>Well if Jet calls that saw their "SuperSaw" I wonder what they call one with a 3 H.P. motor?
You do need the TEFC because it is running in a heavy dust environment.
Baldor , Dayton are good motors that most of the boat anchor manufactuers avoid because they can make one cheaper.
If your not running on a dedicated 220 V. 30 amp protected line , then give it serious consideration to realize the most out of your saw and it's motor.
Since I havn't seen this particular Jet model , it would be wise to ask them how much if any you can increase the motor H.P. rating.
FredD
Chuck in ND
>Along with the electrical issue thats been brought up, it could also be that you need a new blade, and or the arbor is out of alignment.
Kevin Rabenaldt
>I agree. I have a Craftmans with a 1 HP motor and I can rip a 2x4 with it. As posted earlier, it may be a electical supply problem. Are you using a light or long extension cord? I actually ran my saw and 1HP dust collector on the same circuit. It worked, but I have since setup the saw for 220v.
Kevin
Steve Woodall
>I am not tripping the breaker. I am tripping the reset button on the saw.
I have tried several new blades, from a high end Amana blade to a thin kerf Freud.
I have double checked all the parameters on the saw setup, and everything is fine.
The only thing brought up that I have not done, is putting the saw on a dedicated 30 amp, 220 volt circuit. I currently have it on a 110 volt 20 amp cercuit and am using an 8' extension cord.
I didn't think the electrical setup was a problem because I am not tripping the breaker, but tripping the saw's reset button.
Any more help or input would be great.
Thanks,
Steve
>How old is the saw? Is it still under warranty?
I was able to rip 8/4 maple, cherry and oak with a 1 1/2 hp motor on my old Sears table saw, so power shouldn't really be an issue.
If your saw motor isn't under warranty, I'd consider replacing it with a new motor. A TEFC 2 hp motor should work nicely.
Re: New Table Saw Motor( Long)
Will Abbott
>I agree that changing over to a 220v supply is a good idea. But using a 30 Amp breaker to protect a motor of this size is asking for trouble. When you double the voltage, the Amps are cut in half. Watts/Volts=Amps But I don't think that it will solve your problem. What is happening is that the thermal overload inside the motor is tripping. This is usually caused by a bearing going bad,or a bent shaft. I would start by removing the blade and taking off the belt. With the saw unplugged try to turn the shaft on the motor by hand. It should turn easily and not make any noise. If it doesn't turn easily, or makes any kind of crunchy or grinding noise I would take it to a motor shop and have them look at it. They would also be able to check for shaft run out. If all that is wrong with it is a bad TOL it might be cheaper to fix than replace the motor. A motor this size should have no trouble ripping 2x lumber.
Will.
Ed Wozniak, Buffalo, NY
>Is this a new saw that always had this problem or is it an old saw and a new problem? If it is a new saw that always underperformed I would suspect that the problem you are having is caused by not getting sufficient voltage to the motor. I used to regularly trip my motor breaker with heavy use until I improved the supply voltage to the motor by changing over to 220V wiring. It can be tricky to determine if a motor is overheating because of mechanical or electrical issues however. It's hard to believe that your problem is that you have an undersized motor.
Gene Gauss
>Just doing some rough numbers in my head, your 1 1/2 HP motor shouldn't draw much more than 12-14 amps running at full load. Before the bearings went bad on the 1 HP motor on my Craftsman, I had no trouble ripping 2x4s. (I replaced it with a 3 HP - I know, overkill). What is the wire gauge of your 8' extension cord. You'll want to have at least AWG 14 or larger (lower number) for that load, but at 8', I would have trouble believing that there was enough voltage drop in that extension cord to cause your motor to go into oveload. Your best bet is probably to pull the motor off and take it to a good motor shop and have them test it. It might just be that the overload trip has deteriorated and is tripping prematurely.
Yes, Yes, Yes
>Good Morning Steve,
I have the Jet hybrid with a 1 3/4 hp motor, also hooked up to 120 volts/20 amp breaker. It is not a dedicated line, however all other duplex outlets are always unused when I crank up the saw. The motor is very strong and will power thru hardwood as it were made of pitted ripe peaches. My previous Jet contractors saw had a slightly less powerful 18 amp motor and you couldn't reasonably stop it. It does sound like your motor to me, and I'd have it looked at professionally before getting a replacement or equal or superior power. It might be lots cheaper also.
George
Sawdust Everywhere!
I think they would call the 3HP a Jet Superduper saw...
And the 5 HP a super-super-duper saw :)
Joe Pack
>I had the same problem with my 10" Craftsman radial arm saw. I bought this saw and used to help build my house years ago. It had all the power I ever needed, never kicking the motor reset. After the house was built, I moved the saw to the basement.
The circuit I plugged into had 6 2 bulb, 4' florescent shop lights on it, plus two 75 watt bulbs, and the saw was plugged in at the farthest run of the circuit, about 80' of wire before getting to the saw outlet. It was not uncommon for the reset button to kick when I hurried a cut through 2x material or anything very hard. The reset even kicked sometimes on start up with no cut being made. There were times when I actually turned off some of the lights to prevent the reset from kicking. I didn't have enough power to start the saw.
Finally I got smart and moved the saw to another location. Same circuit, just closer to the main box, about 15' of run to the saw outlet. I have not had a kicking problem since I moved the saw - about 10 years ago! The problem was not the motor, but lack of energy to start the saw.
For what it's worth, I just ran a new 240v circuit down the wall where my RAS is located. I plan to convert the RAS to 240 as soon as I find a round tuwit (I have a hard time finding those little buggers sometimes).
Here's one.
Dan Donaldson
>I think that you just spelled it wrong and that is why you have trouble finding them ;-)
Thanks Dan!
Joe Pack
>Thanks, Dan. Sure wish I had known how to spell "tuit" a long time ago. I might have finished all those jobs by now.
When I get around to turning my printer on I'll have to print it out and make copies. Too bad I don't already have a round tuit...I would do it now. But if I don't have a round tuit to use now, I can't print out the one I need to turn the printer on.....Heck with it. I'll just go to bed.
>I have a nearly forty year old Rockwell/Delta Contractors saw. It came with a 1 1/2 hp motor and that burned up maybe thirty years ago. I replace it with a two hp Dayton TEFC motor. About two years ago I ripped 2 X 4's into stickers for some lumber I was stacking to dry. I cut about a mile of them, Literally. It seems to me that the over load protector kicked out on a hot day with the sun shining on the motor after about three hours. I took it that both the saw and I had had enough for the day and left it alone until it cooled off. Other than that, it ran hour after hour without tripping.
The saw is on a dedicated 240 circuit with No. 10 wire but twenty amp breakers. The cable is about twenty feet long from the panel. I used what I had.
Two or three points here. That Dayton motor is about thirty years old and is still kicking. I rip anything I want on the saw. I might have to baby it a bit if I am ripping three inch thick maple, but it will eat pine 2X4's all day most any day. I have absolutely no complaint with the motor or the fact that it is 2 hp.
I would think your 1 3/4 hp one would do just as well or nearly so. Take it to the shop as suggested by others and have the bearings checked, runout checked, and check the thermal over load protector.
If they can do it cheaply, you might consider upgrading the bearings anyway.
Check your pulley and belt alignment. Wonder if it is possible for the belt to cause the pulley to over heat and then transfer heat to the motor?
REALLY inspect your electrical supply first !
Pete in Holland, MI
>I have the 1.5 hp Jet contractors saw. It was converted shortly after I purchased it to 220 and never looked back. If you need to use an extension cord to run your saw, head down to the hardware store and buy enough 12 gauge wire to park your saw where you run it, rewire it with the new longer cord, and skip the extension cord.
Extension cords, regardless of their wire gauge or length, are subject to frequent winding & unwinding, leading to progressive breakdown of the wire strands inside. If cords have ever been used outside, corrosion in the male/female plugs will add resistance, and another connection, to choke the flow of current.
I use a 10" 50 tooth combination blade and freqently tear thru 1" oak with very little effort (5-7 seconds to rip an 8' board).
There was mention on another thread about moving your saw closer to the beginning of the circut to making it run better. I hope everyone realizes that most of the 50 cent outlets that are in most houses are only rated for 15 amps. Trying to pull 20 amps thru numerous 15 amp rated outlets does create some resistance at each of the outlets.
Tablesaws do consume a large amount of current. Each piece of the circut (wire size of each length of wire between the breaker and your saw), tightness of connections, current ratings of each outlet, quality of splices) does impact how much current can be pulled from a circut.
Also, if any of your outlets are wired with the cheater "strip & press into the hole in the outlet", rather than securing it with the screw on the side of the outlet, these are not a long term effective means of conveying heavy current. Have replaced many of these outlets & switches over the years, as if hey get overheated, the spring that presses against the wire to make the connection loses its action, thus leading to resistance and will cause down-stream voltage/current losses.
Re: REALLY inspect your electrical supply first !
Fred Davis
>At last a knowledgeable reply on power supplies, sounds like you pulled as much wire over the years as wood over a saw.
One thing about moving closer to the source , think about all of the miles saved walking to the branch panel and resetting the circuit breaker. ;-))
FredD
