OT - Removing & capping plumbing lines?
Ken Platt (Granby, CT)
>Folks -
I am removing a small sink, and don't know what to do with the old water and drain lines afterwards. I can get to the place where the water lines take off from the supply in the basement, and there are shutoff valves right at the takeoff. However, I'm thinking that relying on the shutoff valves to hold forever seems like a really bad idea. The piping is all copper. So, is there some sort of cap for this? Something that could be put on without the capacity to solder joints?
Also, is there something besides my recip saw that I should use to cut away the pieces of piping? I'd like to take out the entire line so that I can seal up the holes in the walls (these pipes run out of the basement, into the non-heated garage, then back into the house. And, yes, they tended to freeze up on a regular basis). There are any number of turns in that tortuous route, so I'll have to make a number of cuts to get the piping off. I do have nice bimetal blades for the recip saw.
Lastly, I'd also like to remove the drain pipe. It is black plastic, of course, I'm assuming that it's made of PVC. Do I just get any PVC cap and glue it on to prevent backup of gases, or is there something special I need?
Many thanks from a total plumbing dunce -
Ken
Re: OT - Removing & capping plumbing lines?
Rod Peterson -- Ormond Beach
>Re: the copper—there may very well be a compression fitting that will cap it. Check the plumbing department at your store. I always use the solder on caps. Soldering isn't hard and it may be a skill you should acquire anyway.
Re: the DWV—black means ABS (also a plastic). You don't need a “cap” per se—you should be able to find a thin plastic disk with a lip that will fit inside the pipe (the lip rests on the end of the pipe). It's designed as a temporary plug, as in rough-in work, but since DWV is by its very nature, unpressurized, I can't imagine it wouldn't be adequate.
In any event, there are specific PVC solvents, specific CPVC (water supply) solvents, and specific ABS solvents. Fortunately, there are also one-type-fits-all solvents, I believe.
Rod
Addy Protocol: reasonably experienced but unlicensed DIY plumber
Nat Robison
>I wouldn't suggest using a recip saw on the copper. I would pick up a $15 tubing cutter at Lowe's or HD. I fear the recip saw would leave the ends ragged and unable to be soldered if need be.
Probably the best route is to solder on a copper cap on the ends of the lines. If you truly want to go solderless, cut the pipes and put on new ball valves with compression fittings and just leave the valves closed. I, personally, wouldn't have a problem leaving a closed valve with no cap on its line, as long as no one opens the valve.
You can also get caps called Shark Bite which don't use solder but you might have to buy a proprietary tool to use with them.
I suggest you spend an hour practicing soldering and you'll probably find it's not beyond your capability......and you won't worry about tackling a small leak or a new valve next time.
If you dont' want to try any of this, a plumber could do all of this in 1-2 hours.
Lee Gordon
Lee Gordon
>As Rod mentioned, the black pipe is not PVC but ABS (some people say ABS stands for "All Black Stuff"). I'm not sure if I recall seeing a pipe cap that's a compression fitting but you can probably buy a compression fitting that has screw threads on the end and get a threaded pipe cap to match.
And while you're at the plumbing department, you can pick up a tubing cutter. It will do a neater job of cutting those copper pipes than your recip saw. If the copper pipes are very close to the wall, you can get a mini tubing cutter with no "tail" that works in tight quarters.
Here's a normal one (with a "tail"):
And here's a mini one:
OH, MY , no recip saw ! . . .
steve mackay
>invest in a little "pocket" tubing cutter. Cheap & handy little bugger. If you don't have one invest in a propane torch kit WITHOUT the neat-oh push button ignition. Another handy tool. All you need now is a copper tubing cap ! Easy as cake ! If you've never sweat-fitted practice on some clamped into a vise first. I learned its not alchemy after the first try !
Flux, flux, flux!
>No matter how clean or how hot you get the joint, it will leak unless you flux. Also, heat the fitting, not the pipe. Really, it's easy.
Rod
You're right ! . . .
steve mackay
>Dad told me another one I follow now also. Before you go at it with the steel wool, put on a pair of latex or other such gloves. One fingerprint on any surface is enough to leak. And don't forget "The Sound". "ZZZZZZSSHHH-SHTIP !". Then you know the solder went all the way round. (Did I spell that right ? :))
Re: And the other part Dad said ...
Glenn Madsen, SF Bay Area
>EVERY plumbing project requires three trips to the hardware store. No matter what. There's no way around it.
For the OP: We did a very similar thing with our wet bar. Never used it, and demo'd the drain and feed lines. There's a story there, but not for today. Let's just hope you have a better time than we did. ;-)
Works like we want it to now, though.
Jason Roehl in Lafayette, IN
>Well, the times they are a-changin'. My last plumbing project (which included my first foray into soldering copper) only required TWO trips to the blue Borg. One for the initial materials and the second for some more fittings after I learned how important flux is... The other part of the project was repairing a cracked section of ABS drain pipe. As Rod suggested there may be above, all-purpose solvent/glue combos do exist.
As an alternative to soldering on some caps, there are white PVC slip-on fittings available. I used them when I installed a utility sink in my shop/garage last summer. I thought to myself, "Surely there can't be something this simple and still be watertight..." But, they are still holding fine. They also have a little gray collar in them that you can compress and slide the fitting back off to be reused, too. Sliced bread comes to mind...
Jason
>I can solder. It's easy. Usually. When it's not easy, your house burns down. If you watch someone do it, it looks so easy you will be tempted to try it yourself. The problem is that there is some finesse to it and you can't see the magic. If you do a practice piece, say at your work bench and you clamp one end in the vice, it will work like a charm. There are a few steps in every solder job. Cut the pipe off neatly. clean the end of the pipe and the inside of the fitting. Apply flux to both. Heat the fitting, good and hot, but not too long or too hot. Apply the solder, and let it cool. Just that easy. Unless it's too near a piece of wood framing. Then things atart to get dicey. Or is it it too near the valve you mentioned or another fitting, you can "unsolder" the joints on that. If there is even a littler water in the line, you will never get it hot enough. There are ways around all the problems, but that is what apprenticeships are for. Use some other compatible end cap.
They others are right about the black plastic DWV, it's ABS. You can get the right glue or the universal stuff and use that. If you buy a plug or cap, be sure it is suitable for ABS. (Black also). Even the universal glue won't properly glue ABS to PVC.
You can also buy a soft rubber cap that has a hose clamp on it. Often reffered to as a "fernco" which is a name brand. No glue, no issues, just put it on the pipe and tighten the clamp.
Re: OT Fernco cap
Kneale Brownson Dreaming of the Snow in N. MI
>I'd use the Ferno Cap mentioned for the drain. I'd have no problem leaving just a stub of pipe on the downstream ends of the valves that shut off the two water lines, especially if I removed the handles to the valves, but if you want to sweat on some caps, you need the tubing cutter mentioned earlier and Here's a primer on sweating copper.
I'd also use whatever you find works for extracting the pipe you want to remove. Personally, I'd use a short-stroke air saw with a metal cutting blade, because I have one, but I'd probably try a recip. You're not planning to reuse that pipe anyway. Trying to cut each section from between the studs with a regular tiny pipe cutter will become tiring quickly.
Thanks folks!
>I appreciate all the info. I think that the Fernco thing is pretty much what I'm looking for for the drain; anything to get it done easier as that's in a tight location.
I might try the soldering. It doesn't sound too tough, and I already have a propane torch just sitting there....The sharkbite thing sounded like a possibility also.
Off to the borg....seeking as usual to make just 1 trip - a guy can dream, can't he?
Ken
OK, there's a story there...
>Wanna share?
This is also a wet bar removal. I can't imagine what the people were thinking when they stuck this in a little alcove. They even tiled a little area in front of this 3' x 3' area in which they shoved a solid-surface counter with a sink in it. And, this is maybe 12 feet from the kitchen. It just seems like an utterly ridiculous waste of effort and materials.
The alcove is right next to the door to the garage which we use as our main entryway, so I'm going to make it into the mudroom (? maybe the better term would be a mud-alcove) which we need but lack. A built in seat, a cabinet above, some hooks or maybe a shaker-style pegboard running around the perimeter. Should be a fun project. I'm doing it in conjunction with putting a wood floor in the room that this alcove is off of.
Ken
del schisler
>go to this site and get end stops http://www.sharkbiteplumbing.com/All-Products-C1.aspx
Justin
>One problem with a sawzall to cut copper is that it shakes the living hell out of the pipe, occasionally breaking joints that weren't real good to start with, & you can't get a copper fitting over the pipe.
I heat the fitting, holding the solder on the top of the pipe/fitting seam, when the solder melts to the fitting, I heat the pipe & run the solder over the sides, till it runs out the bottom. Then wipe with a rag to neaten things up.
Justin
Re: OK, there's a story there...
>about 2000, maybe 2001, the hall bathroom vanity collapses under the weight of son #2, 6'5", maybe 280 at the time. Hey, it's 25 year old mdf, in a California affordable house built by a developer.
And it's fall, and there are 40+ people coming for Thanksgiving, and I'm building a new bathroom vanity on the Shopsmith, and get everything together, including the sink and faucets. Thanksgiving morning, and I don't have everything I need to make the sink connect underneath to the drain. And NOTHING is open on Thanksgiving to sell plumbing parts. We scrounged through three garages and still found nothing.
So son #1 strips out the drain pieces from the wet bar sink, and we hook them up with the hoses from am old carpet cleaner, duct tape, silicone caulk and a hearty prayer, and manage to have 49 people for the family and friends celebration at the house. The temporary counter was clamped on with a Jorgy clamp. The drain was backed up by a dishpan under the sink. And a towel caught what everything else missed.
It was all done right by Saturday morning. Except the wet bar has never been stripped out the rest of the way. The sink drains to daylight, and the faucet fitting have been closed shut, and duct taped. Don't look too closely. It's not an entirely professional job.
And it's only been 6 or 8 years now.
Just one problem with all that...
>SF isn't usually considered Redneck Territory! (Just funnin' ya...)
Jason
