house siding
house siding
house siding
woodenleg
>I have to replace some siding on my house that is pressboard. I am thinking of using hardie board, is there a certain blade I need for cutting this cement board, do I have to worry about the dust getting into my saws? All of the cuts are normal cuts, nothing fancy, no rip just crosscuts.
Thanks for your help. Dave
Re: house siding
Lee Gordon
Re: house siding
Lee Gordon
>Hardie makes a guillotine that cuts the planks like a paper cutter and produces considerably less dust than a saw.
Re: house siding
Re: house siding
>I used a "junk" carbide blade when I had to replace the siding on the dormers on my old house. I then cleaned and lubricated the CMS thoroughly. I did wear a respirator, that stuff puts out a lot of nasty dust.
I did take the blade in for sharpening a couple of months later and it cuts as good as new.
YMMV - the guillotine is probably a good investment if you have to do it again.
Re: house siding
Re: house siding
John E in SC
>My whole house is sided w/ Hardiplank, and the guys that did the siding just used a circular saw with a cheapie carbide blade. Makes an awful lot of dust, and if it were me, I'd probably buy a "throwaway" cheapie circular saw (Wal-Mart or Harbor Freight) rather than taking a chance at screwing up my good saw. A $30 saw will probably be more than adequate, and will be much cheaper than the specialized tool. (And hey, $30 isn't even half a tank of gas now!)
John
Re: house siding
Re: house siding
Glenn Madsen, SF Bay Area
>Do you suppose the siding chopper is a rentable item? They showed one this morning on This Old House, on DIY. BTW.
Re: house siding
Any old blade run backwards
Re: house siding
Re: Yes! Any old blade run backwards
Bob Entwisle in NJ
>Agree, thats what we used to do for AL siding, run a junk blade backwards.
Re: house siding
Re: house siding
>Score it and snap it. You can do a piece or two with a razor knife. For more than that go to the tile section of Any big box store and buy the tool they have for cutting the backer board. Its a handle with a small head with a single carbide tooth out each side. Less than ten bucks. Use a square, score across a couple of times and break the planks. Use a really coarse rasp to clean up the ends if necessary. Makes some dust, but not nearly as much as a saw and does not launch the stuff into the air as much. A mask is still a good idea, but at least you won't be standing in a cloud of dust.
Can't imagine you won't need the saw for some cuts. Seems like there would have to be some rips under windows, cut outs for boxes, whatever, but scoring it is much quieter and less messy. Try it. If you want to be persnicity, you can score both sides.
Re: house siding
No! Any old blade run backwards
Charles M
>Do not attempt to use a carbide tipped blade backwards. You could break a tip loose and cause serious injury.
Charles M
Freud America, Inc.
Re: house siding
Cutting Fiber Cement Boards
Charles M
>There are saw blades made specifically for cutting fiber cement and most have very few teeth so that they create more chips than dust (although dust is still a concern so wear an appropriate dust mask). We offer them in both carbide tipped (D0706CH -7-1/4 X 6T) and PCD diamond (D0704DH - 7-1/4 X 4T) as well as other sizes and they are approved by JamesHardie.
Charles M
Freud America, Inc.
Re: house siding
Re: house siding
John from Cincinnati
>John
I am siding my Bugalo now with Hardi plank clapboards with a 4 inch reveal. Saws of any type generate a ton of nasty dust and sound terrible. I have a MK tile saw that I normally use for tile jobs but it cuts Hardi plank without dust and without noise. After using it I would never use a saw again.
John
Re: house siding
Re: Cutting Fiber Cement Boards
Pete in Holland, MI
>Worked on a couple Habitat houses along the Gulf last month. Hardie board lap siding was used. There is a carbide blade made specifically for this cement based board, but a regular blade lasted almost a day before it was toast. Good idea using a cheap circular saw. The dust is cement based and not good for any machine.
If you use the lap siding, there are some cool plastic hooks that hook on the top of the last piece of siding, register the next piece of siding, then snap away.
