Epoxy experts help! Clear finish problem *LINK*
Dave Mount, 28 F this morning
>Hello all--
I have a run of four canoe paddles in progress. My plan was to glass the blade faces with 2 oz glass. Last night I did the first one and it's as though the fabric did not fully wet with epoxy resin -- it didn't just disappear like I'm accustomed to. The cloth was dry laid and wet from above, I squeegeed it lightly, just enought to spread the epoxy and get it to penetrate to the wood. It did that fine, but the fabric is still clearly visible. I'm not talking about the surface texture, I'm talking about being able to see the cloth and the weave down in the epoxy.
Last night I thought it was perhaps because my resin was old so I bought fresh today and did a test patch (not on a paddle) and had the same result. I also tried applying more resin and trying to work it into the fabric more, but that does not help. I also tried heating it with a hair drier and that didn't help either. There are no actual "bubbles" under the fabric, but it's like there's a tiny amount of residual air down in the fabric that won't come out so the fabric becomes clear. This is not a generalized fog or blush, the resin itself is crystal clear -- the problem is specifically in the cloth.
Any ideas? I'm using West Systems 105 resin and 207 hardener. The shop is at 60 degrees which is at the bottom of (but within) the recommended temperature range. The cloth I'm using is 2 oz cloth (presumably E glass, though it's not marked as such) distributed by Hobbico, I've give a link to it below. These are cherry paddles and having them nicely finished is important to their intended audience.
Long as I'm asking, do you think 2 oz glass is too much for this app? I have some 3/4 oz also. . .
Any help appreciated,
