SWMBO wants this painted black
Pat Evans
>This temporary TV stand was originally just open shelves made from scrap while awaiting construction of an entertainment center. Two years later and we haven't agreed on the design of the entertainment center, so she wanted drawers to hold all the DVD's, CD's, etc. that accumulated on the shelves. The drawers are left over oak veneer plywood from another project with 1/4" oak edgebanding. Now that it's made, the grain pattern is a little wild for her taste and she wants to paint the drawer field black and leave the oak edgeband. What is the best way to fill the grain so I can get a smooth, flat painted surface? The current finish is stain and 5 coats of tung oil.
Re: SWMBO wants this painted black
Re: Grain Filler
>I use Crystalac waterborne filler. Does very well. Apply with a plastic spatula to work into the pores in both directions with a finishing stroke with the grain. Allow to dry a bit per label instructions, then gently rub off the excess moving across the grain with a piece of burlap. Allow to dry. Sand lightly with a block across-grain and vacuum off. On oak or walnut I usually thin another small batch and reapply to catch any pinholes I missed. Rub off / sand as before. Since you're going with a colored finish (black lacquer, etc.,) that should do it. If you were applying a clear finish, you could tint the filler to match or contrast with the wood's natural color (or stain) or just leave it untinted. When a clear finish goes on, the filler becomes invisible.
Hope this helps
mm
Thanks Mark
Pat Evans
>Sounds like just the trick. However, neither Klingspor or the borgs around here carry it... at least according to the web. Any suggestions on where to get it?
Question for Mark
David Yoho
>Mark, I have a container of the Crystalac waterborne filler here unused as well as several gallons of Crystalac, which I have used before. Now that my HVLP is working correctly, I plan to use it on more projects.
My question is - since the filler is water based, will it stick to the oil finish used on the oak? Would a barrier coat of dewaxed shellac be needed?
David
Re: Answers for David
>1. Should stick with no problem so long as the oil is fully cured. If there is any solvent or incomplete polymerization of the oil, you'd best wait until the oil has had a good month or so to cure.
2. That said, the general rule again is - "shellac sticks to everything, and everything sticks to shellac" so long as you make sure your shellac is dewaxed and uncontaminated. If you want to mist on a 1lb cut as a tie coat nobody will know UNLESS you use old shellac. I've spoken with several very knowledgeable people, including Jeff Jewitt and Jeff Weiss, the Pres. of Target Coatings, and they have been dealing with a shellac condition under waterborne finishes known as "cold checking" where a shellac sealer under waterborne finishes actually fractures and produces line patterns such as are seen on antique pieces. The cure is to mix your shellac sealer/tie coat from dry flakes, do not use it beyond 4 months from mixing, and keep it thin. In the case of Zinsser's SealCoat, it was suggested not to use it in this application if it is more than 1 year old by the label's born-on date.
I did a Ladies Spindle Morris chair in cherry that cold checked on me. I had used an oil finish to pop the grain, then several coats of tinted shellac to tone out uneven color in the cherry, and then top coated with Target's waterborne lacquer. Whole piece had to be stripped to bare wood. It was not fun.
You do not need anything over the Crystalac before final finishing.
Hope this helps
Re: Question for Mark
Fred Davis
>David,
try some sherwin-williams oil based and tintable naturally , wood filler , that eliminates the water borne filler problems.
now about those shop shots................
FredD
It Seems Like.....
David Yoho
>...the hurrieder I go, the behinder I get! I know it's been a while but I will get them done as soon as I can - promise!
David
Thanks Mark
David Yoho
>Pat said he applied five coats of tung oil. The problem I see is whether it was pure tung oil or something else with a tung oil base. Either way, I think I would tend to go with what I believe is the safe route and apply a coat of Seal Coat before using the water based filler.
I haven't looked lately but I originally got my Crystalac products from McFeeleys. I think the Crystalac over the Lockwood water based dyes I've been using will be a good combination and I want to try it out as soon as I get the chance.
David
Steve Schoene
>Let me ask a question. What brand was the tung oil that you used? If it was Formby's, for example, which is really a wiping varnish, not oil at all, 5 coats over stain would be roughly equivalent to 2 brushed on coats of varnish. I would be concerned that much varnish may have smoothed the insides of the pores so much that the pore filler can't get a good "grip" for adhesion.
It was Formby's
Pat Evans
>Steve, it was in fact Formby's. I wonder if that changes Mark's recommendation?
Nope |;-}}
>I always seal the wood before filling and have used Crystalac over two or three coats of poly with no issues.
Re: SWMBO wants this painted black *LINK*
Jim Dillon
>Pat,
If by chance Homestead Finishing doesn't have what you need, McFeely's also carries the Crystalac waterborne finishes/fillers/toners etc.
Jim
McFeely's
