Wood movement?
Wood movement?
Wood movement?
>Yes, I have a wood movement calculator. It's just that sometimes, I don't know whether to believe it!
The indoor ramp I am building is of southern red oak and is 36" wide by 60" long. It is kiln dried. The boards are plain sawn. The boards of the ramp platform are oriented so that the length of the board (longitudinal) is the 60".
Obviously there will be some wood movement. I was figuring on maybe 1/2" or so. The table generated for radial wood movement sort of agrees with this. Then I looked at the tangential wood movement table. It was showing about 1" or greater movement.
I was planning on mounting the ramp on a bottom support with screws in the center boards. I was planning on routing channels in the two side supports (1/4" to 5/16" deep) to allow for wood movement into the side supports. If the wood movement is going to be 1", that isn't going to work that well.
Will my 1/4" channels work? Or should I modify the design?
TIA.
Re: Wood movement?
Re: Wood movement?
Norb - Cumming, GA
>JL, I don't think that the humidity changes to total amount where we live (here in N. Georgia). Most calculators will show total wood movement from bone dry Arizona to sauna like Miami (in the summer). Here we seem to go from 15% relative humidity to about 35% in the summer w/ Air Conditioning. As this is a piece for your house, I wouldn't plan for, nor will you see, all that movement.
Now - where did you get all that red oak for $2/bd ft???
- Norb
Re: Wood movement?
Re: Wood movement?
>Do you mean the ramp surface boards will be glued into one solid 60" width? If so, seems like it would be better to make each board independent and let any gaps between them widen a bit as needed. Gaps would add to the traction as well. But I agree with Norb, seems like it would move very little if kept indoors.
Re: Wood movement?
Re: North Georgia Hardwood *LINK*
>Up in Cleveland, GA. It would be about a 85 mile round trip for you.
Re: Wood movement?
Re: Wood movement?
>The length is 60" and the width is 36". Two of the three pieces were 60" x 13" and the third was 60" x 10".
Re: Wood movement?
Re: Wood movement?
Sgian Dubh
>If we make a few assumptions such as:
*The wood is currently 7% MC and you build the ramps whilst it's still at this MC.
*Next that the assembled ramp ranges in MC from this low of 7% to a high of 13%, not unreasonable figures for houses with climate control.
*The width of the panel at the time of building the ramp is 36".
Now we plug in some numbers viz:
*From 30%- 0% MC the tangential shrinkage factor for red oak = 8.6%
*From 30%- 0% MC the radial shrinkage factor for red oak = 4%
A few sums tells me that you can expect the following, remembering of course that the panel starts at 7% MC, is 36" wide at the time of construction and that MC ranges from 7% to 13%:
*Tangential expansion from 7% - 13% MC = ~5/8" (final panel width- 36-5/8")
*Radial expansion from 7% - 13% MC = ~ 5/16" final panel width- 36-5/16")
The critical bit of information really is that you can expect a maximum width change of about 5/8" between 7% and 13% wood MC. And this relies on all the wood in your panel being purely tangentially cut. The chances are you'll have a mixture stuff that's tangentially cut, rift cut and figured cut, and maybe a bit of radially sawn, so it would be reasonable to assume a maximum width change of about 60- 70% of that 5/8" figure, therefore about 7/16" to 15/32", or thereabouts. Slainte.
Re: Wood movement?
Re: Wood movement?
>Thanks. That sounds close to my SWAG of 1/2"
