A few patina recipes (long)
>These are for copper, bronze, and brass. Prep the metal with a light sand blasting or scuffing to give it some tooth, and clean with a phosphoric acid cleaner or strong detergent rinsed well.
Blue
Sodium Thiosulfate 60 grams
Nitric Acid 1/2 teaspoon
Water* 1 quart
Use of tap water reportedly produces blue-gray color*
Use as a Dip only. Make fresh.
Results in a transparent patina.
Wear a respirator.
Apply in a well ventilated work area.
Royal Blue Ingredients
Cupric Sulfate 8 parts
Ammonium Chloride 4 parts
Sodium Chloride 1 part
Acetic Acid, Glacial 3 parts
Water 128 parts
Use hot or cold.
Results in a semi-transparent patina.
Wear a respirator.
Name/Author Ingredients
Green, Apple
Sodium Chloride 5 parts
Ammonia( Ammonium Hydroxide) 4 parts
Ammonium Chloride 5 parts
Acetic Acid, Glacial 4 parts
Water 4 parts
Use cold. Results in an opaque patina.
Wear a respirator.
Light Green
Ammonium Chloride 16 parts
Sodium Chloride 16 parts
Ammonium Hydroxide 16 parts
for deeper green color, add*
Cupric Sulfate 16 parts
Wear a respirator.
Green
Sodium Thiosulfate
Aqua Marine Blue
Cupric Nitrate 250 grams
one of the following blue dyes
Cerulean Blue or 2 ounces
Methylene Blue 2 ounces
Use hot. Make fresh.
Wear a respirator.
Cobalt Blue Ingredients
Solution 1
Cupric Nitrate 125 grams
Cobalt Nitrate 85 grams
Water 1 gallon
Solution 2
Water 1 gallon
Apply solutions 1 and 2 alternately over heated metal.
Results in a semi-transparent, blue-black marbled patina.
Requires several coats but over application may cause flaking.
Wear a respirator.
Green
Green, Antique
Step 1-Apply "Basic Green" patina hot
Step 2- While hot, apply following solution.
Potassium Thiosulfate 2 ounces
Water 1 quart
Use hot or cold.
Wear a respirator.
Green
Basic Green
Cupric Nitrate 1-4 tblspn
Water 1pint
Use hot.
Wear a respirator.
Apply in well ventilated work area.
Green, Natural
Ammonium Chloride 8 parts
Re: A few patina recipes (long)
Metals, patinas and woodworking
>Thanks for the recipes, Clint. I'd like to try some of these out. What would be really valuable would be photos of samples of these patinas on the different metals you mentioned. Also, how nasty are these mixtures? Any particular safety procedures? Rubber gloves? Vapor mask? Goggles?
I'd also like to hear some suggestions from you and other folks as to different ways to incorporate metals into woodworking projects. The last time I had occasion to use a patina was when I made some outdoor lanterns of bronze and brass. They came out really nice, although I don't have any photos of them, believe it or not.
Anybody wanna suggest some applications to inspire us? Projects you've completed that included metal parts or embellishments?
Re: Metals, patinas and woodworking
>Rather than try to cover the topic based on my limited experience, I suggest one or both of two books: The Colouring, Bronzing and Patination of Metals," Library of Congress #90-49860, and "Contemporary Patination" by Ron Young, available from his website, sculptnouveau.com.
Also, rather than mixing any of the formulas from scratch, I suggest first getting a pre-mixed version, available from various sources. I've dealt exclusively with Sculpt Nouveau. They have a full line of coloring and patination products, as well as metalic emulsions that can be colored and patinated. Ron conducts weekend workshops on the process and techniques. Another source for patination solutions is Birchwood Casey.
If anyone wants an up close and personal view of some of the products and examples, I'd be happy to host a visit.
Here's an example of combining patinated metal, bronze in this case, and wood in a furniture project.
Clint
Nasty mixtures? Precautions? A few (long)
Henry (Raleigh NC)
>Ellis: You asked "Also, how nasty are these mixtures? Any particular safety procedures? Rubber gloves? Vapor mask? Goggles?"
The answers could be complicated, and in a workplace setting they would be. Please note that this opinion is worth what you paid for it � I am not an industrial hygienist or safety officer. I am an experienced user. my comments are not an exhaustive list; there are likely other precautions that I have not listed.
- Ventilation requirements, as well as PPE (personal protective equipment) would be a must is a workplace. At home, I would not even consider mixing these materials inside.
- For these materials I would consider appropriate precaution to include at minimum eye protection, preferable a face shield, as well as gloves (without looking it up I can't recall what materials are acid resistant - online sources would be useful). An apron would be good, but that is not typically something someone has at home; I think you can get some disposable aprons, but I have not seen them retail. Places like Lab Safety Supply will likely sell these (Warning - pseudo political comment follows: buying these items today likely puts you on a watch list!).
- The acids listed here are both very reactive with water and need to be handled appropriately; glacial acetic and nitric are on this list and must be used with precaution.
- The PROCESS of mixing acids is important!
- Repeat - the PROCESS of mixing acids is important!
The chemistry mantra is "Always add acid!"
This means you DON'T scroll down this ingredient list throwing the components into a container in the order they appear in the list.
"Always add acid" means that the water should be the container first and that the acid is added to water. If you do this wrong by adding water to the acid the solution can sputter and splash (hence the need for eye protection). Mixing water and concentrated acids is an exothermic process (it gives off heat); so much heat can be generated that the solution can boil (locally) and cause the sputter and splash. Mix the solutions slowly. While this sputter and splash effect might seem fun - remember that concentrated acids are typically very corrosive to all tissue (eye protections?!). I would have a garden hose ready to wash off any contacted tissue immediately (not that spills should be through your face shield or safety glasses, gloves or apron).
My biggest concern with this list, aside from the comments above, is the disposal of the used/spent solutions. Before you purchase or mix any of these solutions - please consider how you will dispose of the waste solutions. I would think that any of the solutions made from the listed recipes would be considered hazardous wastes (in a workplace setting). I do NOT think it is appropriate or responsible to simply pour such solutions down the drain, into the septic system, or onto the ground behind the shed, unless you KNOW that this is permissible.
I do not know what the appropriate waste disposal method would be here; if I were to do this, I would label and store the waste (separately, NOT mixing the various solutions). The only disposal method I would consider is to bring this material to the local (municipal) hazardous materials drop-off point (where paints and solvents should be brought).
Summary �
Know how to handle such materials � especially the concentrated acids.
Know how to properly dispose of waste solutions.
Henry W
Hardware example
>This was originally polished cast brass. Sandblasted and treated.
Patinated metalic emulsion
>This chunk of cypress was first heavily painted with a couple different copper alloy powder emulsions before treatment with a couple different patina solutions.
Steven Antonucci
Acetic acid is basically vinegar
steve antonucci
>A good precutionary note for the next time I make a salad dressing :-)
I've been patinating with household chemicals (Ammonia, vingar and salt) and while it's a GREAT idea to follow your procedure in general, most of what we're talking about is safe to do at the kitchen table or worst case, your driveway.
Steven
Steven Antonucci
Exactly the look I want!
steve antonucci
>Was this a cold process or a hot process? I might ask you "how hot" if it's hot. I've seen David Marks flame real copper, but my objects are made out of wood and I don't want them to ignite.
Thanks
Steven
Re: Exactly the look I want!
>It's a cold process, helped along by doing the patination on a hot day in the sun. It's basically a three step process. (1) Base coat the piece with any latex or latex acrylic; (2) Apply several coats of the desired metal coating. I often go to three or four heavy coats, sometimes puddling one on top another, say copper over brass. (3) As soon as the final coat has firmed up but not cured, within a half hour of application, spritz on the patina solution. On a warm day, the color will start to develop in a few minutes and mature within a hour. On a large piece, different patina solutions can be distributed to bring up varied effects. Likewise, the different metal coatings will color differently. Ammonia and/or vinegar will emphasize different reactions. The final outcome is subject to the interactions of the metal coatings, patina solutions, and temperature.
After the piece is dried fully, it needs to be thoroughly hosed down to remove any remaining chemicals. I usually topcoat with a solvent lacquer, but a water borne can be used.
Clint
Re: Vinegar is 5% solution; Glacial is 100%
Henry (Raleigh NC)
>Vinegar is acetic acid - true, about a 3-5% solution.
Glacial acetic acid is a 95-100% solution. See the difference?
Just because the dilute form is used in the home does not make the concentrated form 'safe' to use without precautions.
The "It's just vinegar" thinking is exactly what I was trying to address. I am simply trying to make others aware of basic safe handling procedures, especially as would be required in the workplace. Did it sound a bit overly cautious or even scary? Good. Corrosive materials should be handled with care! Handled as needed, but certainly with care and precautions.
What you do at home is clearly your choice. I typically do not have a guard on my table saw - that does not make it safe to use this way.
You could dump these solutions in your swimming pool and may have no issue with it. That does not make it the right disposal method.
My suggestions are clearly not the definitive answers - but I hope people think a bit before they create reactive solutions using corrosive materials.
Henry W
ben d.
>Getting in on the subject late but here is a web site that is for ordering pre-mixed solutions and how to use.
I have not used any of these as when I was searching I was anticipating a need which did not develop.
Maybe it will help someone.
http://www.artchemicals.com/Tiffany-Green-Patina-P3765C0.aspx
ben d.
Steven Antonucci
Here is a vessel I did with vinegar and ammonia
steve antonucci
>I wasn't trying to suggest that anyone should play with acid or any strong chemicals in an irresponsible manner. I was only pointing out that relatively weak concentrations were easily accessible and worked pretty well.
In the past, I've fumed oak with good results with household ammonia. Reading the MSDS on aqueous ammonia was more than enough to scare me away from it, as I'm sure would the MSDS on acetic acid. I don't doubt that it could be safely diluted with water and dumped down the drain.
Steven
Re: Here is a vessel I did with vinegar and ammoni
Henry (Raleigh NC)
>Steven: You wrote "I was only pointing out that relatively weak concentrations were easily accessible and worked pretty well."
I agree absolutely. If results such as the beautiful work shown in your picture are available using dilute household materials, I hate to see recipes 'floating around' that call for usage of more corrosive solutions.
I was more than a little taken aback to see a recipe call for glacial acetic acid or nitric acid. I guess people can get their hands on these retail - but I shudder to think about that. Substitutions like you suggest (using already diluted acetic acid, vinegar, in place of diluting concentrated acid) are something that takes a bit of knowledge to accomplish. The recipes as posted do not lead the uninformed to such substitutions, and your suggestions are right on.
I did want to warn potential users somewhat about the precautions necessary for usage of such materials.
I wish I could suggest such household materials substitutions for some of the other materials on that list.
Henry W
Mike Schwing from Md.
>Thanks for the recipes Clint. I have been experimenting with patinas as well. This little yard creature is actually white plastic underneath. I painted on a copper paint and treated it with various patina chemicals as provided to me by Sculptnouveau.com (plus a little plain old vinegar as described by Steve). This little guy sits out in the rain and continues to age, as I haven't sealed the copper.
These things were done in the same fashion, though they are made from oak.
Looks great
Into each life...
>a little caveat emptor must fall. If some knucklehead wants to stick his nose in a beaker of nitric acid without doing a bit of homework first, he deserves what he gets. There is such a thing as personal responsibility.
Clint
Steven Antonucci
Darwin's Theory of Natural Selection at work...
steve antonucci
