Finally got my HVLP working (LONG)
David Yoho
>I have a Fuji 3-stage HVLP unit that I must have bought about 12 to 14 years ago. I never thought it sprayed quite right in the early going but just put it off as my inexperience with spraying. Later I started to realize it wasn't me but the gun. The one thing I always did was to make sure the gun and all air orifices were clean after use. The thing performed so badly that I just stopped using it. When I did use it, I had to use the "round" pattern setting to get a decent flow of material and many times that was too much.
When I traveled up to the woodworker's get together this weekend in New Market, VA at Charles Neil's shop, I took along the entire unit. Charles said he would check it out for me. Charles' good friend and fellow professional furniture builder, Bob Kloes, was down from Wisconsin for a few weeks. He and I went back to the finishing room to check out my problem.
After trying it with some denatured alcohol, Bob immediately saw what I had trouble trying to explain. When the fluid adjustment did no good, he took the entire gun apart to check for restrictions that would affect the amount of spray coming from the nozzle. The gun was clean so he found nothing. After some head scratching, he called Charles in to have a look. Charles found the problem right away. When he disconnected the gun from the hose and saw the amount of air pressure was way too low for a 3-stage turbine, he removed the quick disconnect coupling from the turbine. The air coming out at the turbine was plenty. He looked at the end of the coupling and spotted a washer / O-ring that was the culprit. We removed it and attached the hose back to the turbine. Then I pulled the trigger on the spray gun and the darned thing sprayed like it never had!!!
I might have found this on my own had I taken the time to troubleshoot it like we did but it seemed I never had the time or inclination all those years. It may also have a little to do with my hesitation since I didn't think I knew enough about spray guns to figure it out. At any rate, it's fixed now and spraying like new. All I need to do now is find the time to practice with it.
Here's a shot of Charles Neil (foreground) and Bob Kloes (background) munching on a snack and talking. You will notice on the shelf behind Big Bob a few of Charles' routers. Poor fellow looks like he could use a few more!!!
David
Re: Finally got my HVLP working (LONG)
Jack
>David
I have a Fuji Q4 that I've enjoyed for several years. I prefer it to other, much more expensive rigs that we have in our finishing shop. My guys won't spray with the Fuji anymore because they get tired of filling the cup :-).
If you ever have trouble with that rig again, call Paul Smith at Fuji. He's the CEO of the company and usually answers the phone. Great guy and will do backflips to get you up and running. I've had seals and small stuff like that go out. He always sends the parts and has yet to charge me for them although I'm sure that day will come.
Regards
Jack
