OT--Old hard drive in a new box?
Gary Evans Tallassee, TN
>Hi all,
I was just looking around for the monitor for Beth's old computer to replace mine which is getting a little hinky. I realized that I still have her old box which, as far as I remember, just needs a hard drive. Since her processor is half again as fast as mine, I thought about just moving my hard drive over. I know I'll probably have to load some new drivers, but is there any reason not to do the switchover?
Thanks,
Gary
Re: OT--Old hard drive in a new box?
Glenn Madsen, SF Bay Area
>Moving hard drives is a matter of seeing that they use the same technology. There are a number of them, and have supplanted each other over the years. The new drive in an old box thing might work, but isn't guaranteed to do so. You should first check to see if the cables look similar...
Bill Howatt
>Depends. If the OS, and I'm assuming Windows - don't know about MAC issues, is an OEM version that only runs on a particular motherboard then you will have a definite problem.
The device drivers as you surmise will be wrong so you will need to have them available and Windows activation will have to be redone. A Windows Repair will also likely be required to get Windows to run properly on the different motherboard etc.
You can look up Sysprep on the Microsoft site which will help you deal with the peripheral devices that reside on the PCI bus. Try and set the video to generic VGA or something like that since the video will likely be different.
Another issue is that if you have some obscure problem you will always wonder if you did it this way but it is done. I prefer to do a fresh install to get rid of the programs I no longer use and as a refresher on how I set things up. Of course, many would sooner avoid the refresher since it can take some time.
If you do a Google search you might find lots of info on this topic.
Bill
