Grit additives for polyurethane?
>I was by the paint store the other day to pick up some polyurethane for my ramp project.
Anyway, while I was there, the owner showed me a paint additive which consists of small polypropylene spheres. It typically is added to concrete paint/stain so that the surface is a "non-slip" surface. I believe it is made by HCH (whoever they are).
So, I was thinking - what about adding it to polyurethane? I was just going to use a satin polyurethane for the ramp surface. Do ya'll think I need to put some "grit" on the surface (1:10 or 6 degree slope)? If so, do ya'll think these polypropylene microspheres would do the trick?
Re: Grit additives for polyurethane?
John Veerkamp, Western Mo.
>These grit/non-slip additives work just fine with any type of film finish. Another option is pool filter sand. I don't think for your indoor application you'll need the grit though.
John
3/4" modified should work
Steve Schoene
>Similar spheres are available for marine non-skid surfaces, and I have used them both in that context and on an oak ply surfaced ramp that I built. The spheres I used were much less hard on bare feet than sanded non-skid would have been and became transparent in varnish, unlike sand. The ones I used were made by Interlux.
Kneale Brownson Dreaming of the Snow in N. MI
>I haven't purchased any in years, but the traditional finnish additive to reduce slippery steps/floors was finely ground seashell material. Before I started using that, I found that adding pool filter sand made for too large a lump, especially when used with paints.
Howard Acheson
>You don't say what the ramp is for but let me say that a poly varnish is quite slippery with any type of moisture on it. If you are going to be pushing something up or down the ramp, I would certainly put some type of non-skid on it.
The product you were shown is a good choice. As said, it's used in marine applications.
BTW, if this ramp is going to be outside, poly varnish is the wrong product to use. It has very little longevity when exposed to the UV in sunlight.
