Tree watering question
Phil Joines Krum, Tx
>We got 20 red oak saplings a local nursery was going to trash and may get 40 more. They are 1 to 2 foot tall in 1 gal. pots. The place we want to plant them is too far for a hose. I've heard you can use a plastic bucket with a small hole to keep them watered but don't know what size hole. Has anyone done this? We have a bunch of 4 gal. cat litter pails.
Re: Tree watering question
Rob Hix - King George, VA
>Phil,
I would think that any size hole would do. The idea is to let the water drip out slowly. I would start with 1/16" or less and see how long that took to run out. You can alway make the hole bigger/add new holes if it does not drain fast enough. Personally, I think I would want 4 gallons of water to last at least 3 to 4 hours for a tree that size.
Rob Hix
>This brings back memories. About twenty five years ago, I had two six inch caliper twenty five foot tall red oaks moved with a tree spade. (Giant tree digging machine.) We had to put them at a house I was building. I drove fifty miles round trip everyday for three months to water them. When I sold the house, the buyer's first official act was to chain saw one of them down. Then the neighborhood covenants committee who had decreed the trees in the first place demanded he replant it. He called me and tried to demand I replace it. I dismissed him as an idiot and he was on his own. The other tree lived.
I used Wee-Wee Buckets. I made mine from five gallon plastic pails. Drill a small hole in the side of the bucket down low and set it on the up hill side up hill tree. An 1/8" hole will work. Smaller might also. You want the water to run out slowly enough that it soaks in and does not run away. I tried holes in the bottom of the buckets, but they nearly aways failed, getting stopped up with debris. Ones about a 1/4" up the side were reliable.
Not sure about red oaks, but white oaks are hard to move. Of course, yours are small and that may help. You realize you are moving these at the worst time? You should move them when they are not in "leaf".
If they are in containers, save some for replacements. I would have about 25% spares or more. There will be losses.
You can buy watering rings or even jackets that are made of plastic and you fill them with water every day, but that would get expensive and may not be anymore effective than wee wee buckets. If you had a water supply you could put a soaker ring around each one. I don't know how far it is, but you can run a how a long ways. How you going to get the water there?
paul in AZ
>Schlepping buckets of water to that many trees will get very old very quickly.
How about putting in an automatic -timed- irrigation system? A 50 foot roll or two of half inch flexible hose; couplers; and adjustable bubbler emitters won't be all that expensive. There are cheap timers that attach the 'drip' system to the hose faucet. Consider the expense as a trade off for the free trees.
This will take some one time labor but if you can get by without burying the lines it isn't all that bad. If buried, a few inches deep just enough to cover them can work. Set the day and time, adjust the flow from each bubbler and from there you just let it do it's thing.
Living where i do my system has multi-zones for a variety of plants but I have used the cheap faucet timers and they are quite reliable.
Depending on your winter climate there is the potential of freeze rupture of water in the lines: not a biggie because flexible lines are easy to repair. The flexible lines seem to be pretty resistant to freezing [rigid lines are not] if you can partially drain down or blow out the lines in fall.
John Veerkamp, Western Mo.
>As mentioned you still need to get the water out to the trees.
A 1/8 hole will work just fine. Your best friend will be to mulch the trees heavily. 4" at least 15" in diameter for each tree. This will greatly reduce the water need and keep down competition from weeds and grass.
John
Dale Lenz
Re: Tree watering question *LINK*
Dale Lenz
>Phil,
What you want is the newly planted trees to have maximum root mass prior to the heat/dryness of the summer. Obviously, the root mass is needed to take up every trace of moisture the tree is able from the soil reservoir. A newly planted tree even with moist soil will still suffer from moisture stress if the summer temps. and winds are high. Once again, there might not be enough root mass to take up the moisture demands from the top end of the plant.
If you have the space/place you might want to consider keeping the trees in the containers on the east side of your house or another building or maybe the east side of the drip line of a large shade tree. You want to reduce the hotter afternoon sun on the young trees.
Obviously, you will need to water the tree in the pot a few times a week, if rain has been absent. Consider planting the trees this coming Nov. Prior to planting root prune the root ball, as the root are sure to be circling inside the pot. Please see the link below on how to root prune a containerized tree.
Even though the trees are free, you time is not. Good luck and I hope this helps
Root Pruning
Got 10 more...
>I know it's not the best time to plant but I'd rather attempt it now than see them thrown in a dumpster. For some reason the nurseries around here always have their best selection in the summer, go figure. Well, the first 20 are in the ground and the 10 we picked up today, red, burr and live oaks, will be tomorrow. (we have a LOT of empty cat litter buckets) We also have 25 assorted trees from the Arbor Day people that will be planted in the fall to go with the 12 that went in this spring. We hope to turn our 1 1/2 acres of x pasture into woods. We won't live long enough to see them mature and they will probably be cut down for development once we aren't here any more but what the heck, we can try.
BTW the big box stores and the economy are putting a hurt on the small nurseries in the area. One is closing this weekend and two out of three others I've talked to are loosing money. It seems the borgs get their plants from large growers that are only paid when the plant is actually sold. If they die at the store it's just written off. The small places can't cut deals like that with the growers.
Celebrate the future...
Tom Dunlap
>...plant a tree!
I was happy to see Dale post the link to the ISA site!
My Dad taught me about the bucket watering regimen. It works really well!
Mulch the trees but keep any mulch away from the trunks. think of a donut NOT a volcano.
Tom
Re: Got 10 more...
>Phil,
We built our house 31 years ago in a worn out pasture, I've planted over 300 trees over the years and encouraged dozens more naturally seeded ones. Our house is now in a forest, with many trees over 40 feet tall. Even at 65 I still plant new trees every year. I love trees!!!
John
