Danish Oil & Shellac ?
Barry Rubenstein
>I'm finishing up a project with dyed birdseye maple veneer. I'm thinking about applying danish oil, letting that dry, and then applying shellac.
Can anyone think of any issues/problems with shellac over danish oil ?
Re: Danish Oil & Shellac ?
General Rule
>"Shellac sticks to everything and everything sticks to shellac."
You'll be fine. Be sure to use dewaxed shellac.
Tip: Put your last coat of oil on with 400 SiC paper and a block moving with the grain, wait 20 minutes, gently wipe it off going 45� to the grain. Let dry and scuff with 600 grit paper dry, then shellac. You'll be glad you did.
Why?
Howard Acheson
Dewaxed shellac is only required if it is being top coated with poly varnish or a waterborne acrylic. As he plans no top coat, standard shellac is just fine.
Re: Wax
>Softens the resultant film, and makes the finish more prone to water damage. Dewaxed has greater depth and clarity, IMO.
Re: Wax
Larry Clinton At Frankfort (Central)., Indiana
>I don't know Mark, I do use a lot of shellac - mostly mix my own but have used a lot of Sealcoat (dewaxed). I really can't tell the difference in the final finish (hardness or appearance). I have read articles from "experts", that have said that shellac containing wax is actually more water resistant - others say the dewaxed is more resistant. The only consensus is that if you are going to overcoat it use dewaxed. I do know that we finished all the oak trim in my sons house with stain and "orange shellac" containing wax. He has one window over the kitchen sink. His wife has set many wet items on the window sill. It has been in use for about 3 years, and is just now showing some discoloration. Of course it will take at least 10 minutes to refinish it again!
Re: Wax
Howard Acheson
>The difference in "hardness" between a wax containing shellac and a dewaxed shellac is very, very small. Wax containing shellac is still considered a hard finish.
Re: Wax
>Larry,
I mix my own from flakes as well. While I buy dewaxed, I also put mine through an extra filtering step (coffee filters) before use. The difference in the jar as to clarity is obvious. I use a variety of types from bleached Ultra Blond to Dark Garnet.
Haven't seen any "expert" article re wax content being more durable. Wax is, by its nature, hydroscopic, meaning it attracts water vapor. This is why wax finishes go dull and must be renewed. The reapplication with its solvent base removes the old coating and restores the shine and clarity, Can't speak to your window sill, but have worked on a bunch of shellac finishes with white rings and spots from water stains. Solvent and warmth restores the base and a reapplication then reseals the item.
mm
Re: Wax
>Howard, I've had dry flakes in both wax and dewaxed types. I have noticed that the dewaxed flakes seem to be more brittle with the unrefined product being for flexible.
