>I'm having to replace several hardwood flooring laminate pieces, due to my puppy and his natural tendency to leak. I've started carefully removng the pieces at the edges so I can get to the spot(wouldn't you know it, right in the middle of a 12x12 room, arrrgh) and have come upon a need for advice from this knowledgeable group. I have never dealt with this type of flooring, and am at a loss as to a fast and efficient way to release the sections from the adhesive backed paper product that was used to adhere it to the floor. Of course, the builder told me it was a "floatng floor" that was not nailed down, but he neglected to inform me that it was glued everywhere. Also, not being versed in laminate flooring, I would like to know if the flooring can be reused, due to the fact I am NOT the latest lottery winner and can't see my way to pay for a new floor, with labor to lay it down. ANY and ALL advice and tips will be fantastically appreciated.
>route the middle of the board and cut the paper backing all around the edge and see if it would lift out. Now of course you can not reuse the piece but it is out of the way. Is the material used for the top of the floor refinishable if so I would try to gently sand away the spots and then blend the new finish to look like the old.
>Haven't done this with laminate flooring, but for solid T&G floor repairs I start in the middle instead of the edge.
Set your circular saw to cut a depth equal to the thickness of the flooring, and cut a kerf lengthwise down the middle of the damaged piece (be sure to stop short of the ends). Then use a small prybar to remove the damaged piece.
Carefully cut the tongue off the replacement piece and glue it in place. You probably don't want to face-nail the laminate, so I'd put some heavy weights on it until the glue sets.
>I have put down Wilsonart (similar to Pergo only better) flooring in two rooms. It was a T&G type of product and the glue was applied to the grooves and you slipped the tongues into them. This process often resulted in glue getting onto the paper underlayment, so it could appear the floating floor was glued to the floor. The problem you will encounter is getting the grooves ant tongues cleaned up to allow the new pieces to be installed. The glue Wilsonart provided was 100% water proof. Wilsonart sold router bits for making tongues and grooves, which might work for replacement, but you will have to figure out an edge guiding method so you route the edges exactly right. The strips and 12 x 12 tiles had tongues on two sides and grooves on the other two.
