What are your requirements?
Bill Tindall, E.TN
>I will take the opportunity of your question to explore some blade selection factors.
Requirements- do you mind changing blades to specifically suit a task or do you want one blade that does it all? How thick is the stuff you cut? How finished a cut do you require. How much are you willing to pay to get some improvement in smoothness of cut?
Factors
Safety: I leave a fine tooth 7.1/2 or 8" blade on my 10" saw and only change it for special cutting situations. This blade cuts up to 6/4 stock fine and the saw marks are removed with a swish of a hand plane or light jointer pass. There is virtually no grabbyness with this kind of blade so it doesn't throw things or offer much of any cutting resistance. Hence, great control, expecially for small parts or thin stock.
Smoothness of cut: It seems that many buy solely on how smooth the saw cuts, absence of tooth marks. If you joint after cutting, having a blade that rips glue joints is of no practical value, and there are disadvantages with such a blade. Hence, any name brand blade will do for routine cutting. If the company stays in business they obviously make blades that work. So pick for convenience in buying and price.
Time between sharpening: A blade with some side relief (set) will stay sharp longer and not gum up, but such a blade may leave some evidence of teeth marks.
Versatility: A combination blade is a good choice if you don't like changing blades. If you cut a lot of miters you may want a cross cut blade for this task. But don't attempt to rip with a cross cut blade. They may throw things on a rip cut. If you do a lot of ripping of thick stock your saw will enjoy a coarse rip blade that loads the motor less.
No doubt there are other factors. I used to fret over blade selection and the older I get the less important I consider such things.
