OT: Plumbing
Sean Troy
>Hey all, Does plumbers tape work as well as plumbers putty?
OT: Plumbing
Sean Troy
Re: OT: No
>Tape is only used in place of pipe dope to seal threads in water pipe joints. Putty is used to fill gaps around a fixture's mounting to a wall or counter; it's useless as a pipe joint compound.
Re: OT: No
Sean Troy
>Thanks Mark. My question was about water pipe conection. The extension arm to shower head assembly screwed into the supply.
Re: OT: No
>If I understand you correctly, you're installing the chrome bent nipple from the 90� fitting in the wall on which you'll attach the shower head. Correct? In that case you would use BOTH. The tape (1-1/2 wrap) goes on the male threads to get a better seal (even though it's not a "pressure joint"), and then you use the putty to fill the gap between the pipe and the wall (under the escutcheon ring) to prevent water from splashing back into the wall.
mm
Re: OT: Oh
>By "putty" I'm assuming you're referring to the soft, clay-like stuff your form up with your hands.
mm
Re: OT: No
Sean Troy
>Yes, thats all correct. thanks for the info on the splash back.
