Re: My New Shop-Electrical Question
Larry Clinton At Frankfort (Central)., Indiana
>Howard, I installed most of my boxes about 52" off the floor. That way you can install (& move) benches along any wall. It also allows you to put a 4' piece of plywood against the wall without covering the outlet. I purchased a full carton of outlet boxes (100) & used them all plus. I did go with the cheaper receptacles as those are quite easy to change later if needed. I installed an outlet on every other stud (studs on on 16" center), I also installed extras where I thought I might want one - near the doors etc. I put 3 rows of outlet on the ceiling about 4' apart for my shop lights (and a few extra). Each row on the ceiling is on a separate switch - controlling 8 or so twin florescent light fixtures. I also installed another switch to 6 boxes on the ceiling and installed halogen bulbs in those. I installed one 60 amp 240 V outlet for my large welder. I also installed several 30 amp 240 outlets on the walls, one for the compressor, dust collector, and Unisaw. I really didn't think I would need more but as I was finishing the shop in drywall, I went ahead and added another 5 or 6 along the walls. It was really a great thing that I did as I now have a lot of 240 equipment including my new Planer, Joiner, Surface grinder, and band saw. I have the largest 100 amp entrance I could find and have every breaker slot used. It is sure a lot cheaper and a whole lot easier to install an extra 10 outlets now, than have to tear out a wall to install one later. Here in Indiana all Garage outlets have to be protected by a GFI. You can use GFI breakers but it is cheaper to just install a GFI outlet as the first of the string. I sure don't regret the extra money and time I spent installing all the extra outlets. If I had it to do over, I would probably have added another 5 or 10. I used #12 wire on all 120V circuits and #10 on all 240V (except the welder). That allowed me to use 20 amp breakers on the 120V and 30 on the 240V.
