Flush mount doors aren't flush!!!
Bill H-Evansville, IN
>I just mounted my first set of flush mount rail-and-stile doors. But they aren't quite flush. I mounted them to the faceframe before attaching the face frame to the cabinet and when the assembly is sitting on the bench, they are flush. But when I clamp it to the cabinet, they pucker out and won't stay shut. I'm using Amerock "adjustable" flush mount hinges (like Norm used in New Yankee Workshop this year) and I can see the door mount is bent slightly towards the front of the cabinet (on all the hinges). If I bend them in will this help? Is this an adjustment "feature"? How do you keep the doors shut with no spring motion like the Euro hinges? Is there some trick I'm missing?
Thanks in advance,
Bill
Re: Flush mount doors aren't flush!!!
Sounds to me like...
>...the face of your cabinet is twisted, especially if the face frame and door are flush when resting on a flat surface. I'd try to straighten out the cabinet somehow -- shims under one corner?
Ellis Walentine, Host
Re: Sounds to me like...
>I think Ellis nailed it. I would check the cabinet and be sure its not twisted. Clearly something changes while installing the face frame. Either the frame and door are both warped but just happen to match each other when the are laying on the bench or the cabinet is twisted and pulling them out of shape when they are installed. Check carefully to see if the cabinet is plumb and true.
Dave Bair, Eaton Rapids, MI
>Duplicate the "flat on the bench" condition by setting the carcass flat on it's back and attaching the frame from the "top". This will let you better see what's out of square.
>Thanks for the tips, you guys were right! The face frame must have twisted b/c when I clamped it tight to the cabinet all was fine...well pretty close to fine for a first try. Upon inspection of the doors, I notice that the stiles are bowed up a bit. I noticed some small gaps between the coping on the rails and the profile on the stiles. Could this cause them to bow up upon glue-up and clamping?
Thanks for the help!!!
Bill
