Have a question? Ask Woody!
Can we apply spray polyurethane on
North of the Border
>a painted surface? I once screwed a paint job by spraying on lacquer on an enamel paint surface (lacquer dissolved the paint). If spray from is not ok, how about the wipe-on form? Or what would be a better protective form of overcoat on paint? Thanks
Re: Can we apply spray polyurethane on
More paint
>Oil based enamel doesn't need to be over coated.
Clint
Re: More paint - clarification of my need
North of the Border
>Actually the paint is on a brass with part of the brass exposed (ie paint removed). I want to spray or wipe on a coat that means to protect the metal (not the paint).
>Poly should be OK, but I would lightly scuff the painted area with a maroon scotchbrite first. My first choice would be spray can lacquer. Second choice, exterior water borne poly, if it's outdoors.
Clint
Keep in mind........
Howard Acheson
>....that putting an oil based poly over paint will cause a change in color of the painted areas. Poly has a amber tone to it and the amber will cause a slight change in the paint colors, particularly in whites.
