Electrical breaker pops question
jeff
>Hi all
I plugged my jointer in to test and the breaker popped.
The motor started and was ramping up to full speed when the breaker finally popped.
This is a 3hp 220v motor. 20 amp circuit breaker on #12 wire.
I normally use Square D breakers that have a pretty good overload rating.
So, switched to another outlet and it fine.
Anyone know how much the motor will pull on start-up?
I'm trying to figure out if I just have a bum breaker or I'm too close to the overload rating.
I can rewire and upgrade to 30 amp, but it's a pain in the neck in this spot (The wall is closed up).
I don't have a peak ammeter to test the start-up current draw.
Oh, I do all my own electric work normally.
jeff
