OT - A seriously dumb electrical question
Joe in a Cleveland Suburb
>Hi.
Todays seriously dumb electrical question. No laughing please...
As I've stated here before, I do not like to mess with electrical things. I often hire an electrician for electrical things.
I thought I could handle this little job. I was wrong. I screwed it up.
All I wanted to do was put one of those switches with an outlet on the end of a cord. The idea was to plug my in-a-table router into and switch it on and off. This is one of those outlet switches where there is one outlet and one switch.
I didn't have an instruction sheet, but I wired the green wire to the green ground. Wired the white wire to the silver screw and the black to the copper looking screw. There is two silver and two copper screws. Plugged everything in and the outlet was always hot regardless of the switch position.
So I moved one white to the other silver screw and popped a breaker.
I then noticed a break off tab and broke it off. Now nothing works.
I quit and got a beer. Watched the Cavs lose. Had another beer.
Do I need to get a new one now because I broke the tab off? How are these things supposed to me wired?
Thanks for not laughing...
Joe
Re: OT - A seriously dumb electrical question
Lee Grindinger
Who's laughing?
Lee Grindinger
>The switch is not intended to control the outlet on those units. To do what you want attach the incoming hot (black) to the switch. Attach the other switch terminal to the hot of the outlet using a jumper. Don't attach the incoming hot to the outlet, it has to come through the switch. Tie your neutrals together using a jumper to the neutral of the outlet, then tie all your grounds together with jumpers to both the switch and outlet.
Lee
Lee Schierer - McKean, PA
>I believe you need to connect a jumper across the two silver screws to replace the tab you broke off and then connect your black (hot) wire to the brass screw by the switch side and the white (neutral)wire to the brass screw by the receptacle. If you have an ohmmeter, you can check the function of the proposed wiring before connecting it to your system. Removing the tab would allow you to have the switch control some other device and have the outlet to be wired as always hot.
Lee
I believe they are....
>If you're talking about this type of combo outlet switch, I believe they are intended to work that way.... with the outlet controoled by the switch.
Depending on which tabs you break off, they can be configured several different ways, with the outlet either controlled or not controlled by the switch.
There are wiring intructions inside the box that show which wires go where and which tabs need to be broken. I'll see if I can find it otherwhise I'll attempt to describe which wires go where.
If you're broken on of the tabs incorrectly, I don't think that's a problem because I think you can put it back using a tiny length of copper wire on the lugs.
Happy Woodworking!
Leviton 5225 information  *LINK*
http://assets.twacomm.com/assets/pdf/19120.pdf
Finding the box.....
>I know I've got a new on still in the box somewhere around here, but I can't find it right now to show you the diagram written on the inside of cardboard box.
From memory, I believe the switch has 2 brass screws and the outlet has one brass and one silver screw.
To wire it up as you want, the green wire goes to the green ground screw, the white wire goes to the silver screw on the switch and the black wire goes to the brass screw on the outlet (on the same side as the silver screw). There is no jumper tab between the brass and silver screws on the side with your wires. There is a tab between the two brass screws on the other side.
I only THINK this is the way it goes. You should probably wait until I find the diagram, or open up and existing one in my router table to confirm this, or until someone else can confirm.
Happy Woodworking!
Lee Grindinger
Find a wiring diagram
Lee Grindinger
>That pic nor the PDF info sheet shows nothing relevant. Single pole switches don't use the neutral, only the hot.
These can be wired in such a way to make the outlet controlled by the switch but they sure don't arrive that way, they arrive intended to operate as a switch controlling a remote light or other device and an outlet that is always hot. Of course they can be made to have the switch control the outlet, I described it in my first post.
Lee
Sorry....
>That picture and PDF was only to confirm we were talking about the same sort of combination device, not to explain how to do it..... just wanted to make sure we were talking about the same thing.
I don't remember it being as involved as you described. I thought it was simpler...... as if it was intended to be used like that out of the box and you only had to break tabs and other things if you need the switch and outlet to be independant of each other. Perhaps my memory is failing ;)
When I find the cardbox box with the intructions, I may be embarrassed :)
Happy Woodworking!
Robby Wright
>Run the green wire of the cord to the green terminal. Run the black wire of the cord to one of the switch terminals. Run a wire from the other switch terminal to the brass screw on the outlet. Run the white wire on the cord to the silver screw on the outlet. This forms a series circuit and will properly control the outlet.
Robby Wright
San Marcos, CA
Thanks everybody! I'll give it another try.
Joe in a Cleveland suburb
Lee Grindinger
Joe, follow these instructions
Lee Grindinger
>Robby's instructions are succinct and concise.
Lee
