THE WOODRAT IS BACK!
attaching pedestal table top-grain orientation?
Geoff in Madison
>I need to permanently attach a Maloof-style pedestal table top to its base. The screws go through the arms of the base and up into the top. To account for the movement of the top should I orient the long grain parallel to one set of arms and the end grain perpendicular to the other set (with the screw hole elongated)? Or should I orient both 45 degrees to the set of arms.
Thanks,
Geoff
Re: attaching pedestal table top-grain orientation?
Lee Schierer - McKean, PA
>Make the screw holes through the arms elongated to allow the wood to move with seasonal changes. You will still have wood movement in the 45 degree position, but it will be about 1/2 as much.
Lee
>I believe the original is set at 45�. I would suggest using 'figure 8' fasteners and one or two pegs at the center point to maintain the top's orientation to the base. Without the center reference points (where there will be no movement) the seasonal expansions and contractions may move the top off center over time. The pegs will prevent this.
thanks 45 degrees it is.
Geoff in Madison
Re: 45 degrees
>If you do use the fig. 8 fasteners with your 45� support arms, make sure you mount them so they to pivot freely in response to the movement.
mm
