Latest Project (w/ pics)--Long
Joanne Adler in Pt. Pleasant, PA
>(Go get a nice �cuppa� or a snack�this is long!)
This is Part 4 of my mission to replace (what I consider to be) the ugly furniture in my parents� house. I�ve built an A&C side table for my Dad�s tv area, a huntboard/sideboard as a foyer cabinet, and a side table for the living room sofa. This time I set my sights on their hideous, 25+ year old, chipping, faux-butcher block Formica kitchen table. Over the years I�ve tried to get them to replace it, but they could not find a hexagonal or octagonal table to take its place�and they liked that shape, instead of square, rectangular, or oval. I got them to agree to �round� (I was NOT about to try to make perfect angles, even if you guys insisted it was easy) and said I�d make them a new table. I may be short or small, but my ambition is very BIG!
Some years ago they had their kitchen remodeled (you think they�d have included a new table!) and put in beautiful cherry cabinets. How convenient that cherry is one of my favorite woods and I have a local supply for it. Off I went to visit John at Bucks County Hardwoods. For a design, I knew I wanted a 48� round top and a pedestal base. But I was a little unsure of proportions for the base, in order to have a stable support for the big top. I did a little searching on the web and came across an article about a round walnut table with base that David Marks made. Perfect! Exactly what I had pictured in my head. Only I pictured it in cherry. Solid cherry. That�s a lot of cherry. Of course, my wallet would be happier if I would learn to be Veneer Girl. But what the heck�it was for my parents.
When I start a project, I always try to pick something that forces me to try/learn a new skill or technique. This table was no exception. I�ve never done quite such a large glue-up. I did it in stages, so I wouldn�t screw it up. The big 48� top used 6 pieces. I took a big sheet of cardboard I had from some shipping box and drew a big circle (pencil, string, and tack for a compass). I didn�t want to waste any cherry and knew the glue-up pieces didn�t all need to be over 48�. I used my cardboard circle to fit the boards as I would use them. I just had enough of the nicest cherry in clear boards to make the big top. In fact, there was a big knothole in one piece that I figured would add some character and I�d just leave it and fill a little with epoxy or something (more on this later). I didn�t have enough of the same cherry to replace that piece or cut out all of the light sapwood (which I happen to like and usually leave in on purpose). First I glued up pairs. Then I glued 2 pairs together. Finally, I glued the last pair to the group of 4. It took longer, but this way I only had one glue joint to deal with at a time.
Once my glue-up was all done and flattened moderately, I took my �fancy� large circle compass and drew a big circle on the piece. Good thing I�m used to �going around in circles� a lot! I used a jigsaw to cut out the circle. Then I took a little time to make a simple circle jig for the router. With the jig and a straight bit I cleaned up the jigsaw cut. The other trips around the table were with a sander to smooth the edge and with the router to put a chamfer on the bottom edge and a roundover on the top edge of the tabletop.
The base is made up of a center pedestal with cross supports as feet and arms for the tabletop. The pedestal is a glue-up of 3 pieces, with bridle joinery at the top and bottom. The supports are 40� long, tapered �arms� with half-lap joinery. Half-laps I�ve used before; the bridle joints were new for me. These could have been better or tighter; guess my handtool skills still need practice.
By far, the biggest challenge I had on this project (besides picking up and carrying around a 5/4� or more solid cherry 48� round tabletop�I�m only 62 �� tall myself) was what to do with the knotholes I left in the wood. There was one on the top as well as one on the side of one of the leg cross supports. I could have used patches or dutchmen. But I�ve seen turnings done with embellishments of crushed stone (turquoise, for example), and that gave me the idea to fill the holes like that. At first I was going to use turquoise (it looks so nice with cherry), but then realized that I could probably find some Malachite or Lapis Lazuli in my Dad�s basement (he used to work with semi-precious stones like that)�how cool to use his own stone in a table for his home! And indeed, I was able to find some small pieces of both at their home to try out.
The dead material in the knots had started to crumble out, after all the agitation from shop tools like jointers, planers, sanders. The holes were deep enough to first need some putty (Famowood to the rescue). Then it was on to experimentation for the stone. I posted my questions over on the Turning Board as to how to do this. I got a lot of great advice. I also spent some time reading online. I found that the Malachite was softer and easier to grind up than the Lapis. I made some holes on a scrap of cherry and first tried using CA glue with each of the stones, then epoxy. The epoxy worked better, but I didn�t like the look of the stones crushed like that. Malachite is a beautiful green and black swirly stone (kind of like green cherry!) and I didn�t want to lose that look. End decision: Dig out the knot holes enough to get some pre-cut cabechons to fit in there, whole. I did use some crushed stone or powder as filler in some places. Overall, I was pretty pleased with how this came out. In places it looks as if the wood is bleeding Malachite. I did wind up using epoxy and that helped to keep the integrity of the wood where there isn�t stone, and created a smooth surface. First here�s the table all cut and smoothed with the knotholes. Then closeups of the fills. I almost wished I had used the 'bottom' of the table for the top--there were 3 knotholes there. But I did not have enough Malachite to make patches.
The finish is polyurethane for durability (this table will get a lot of abuse). Many hand-wiped coats of gloss. Light sanding in between coats with successively finer grits of paper. I tried a coat of satin, but thought it looked milky and dull, so I added another or so of the gloss and rubbed it out. Finishing (as opposed to �completing�) is my least favorite part of a project and I�m sure it shows. I�ll leave that skill on the list for improvement, too.
It looked pretty nice from up on a chair or ladder:
Figure 8�s hold the top to the upper support arms.
I did draw the line at building matching chairs with cushions, arms, and casters. My mother and sister were able to find some nice, comfortable ones with a stain that looks pretty close to the cherry. Here are a few shots of the delivered table in Mom�s kitchen (it actually fit inside my Forester!) with the new chairs. Needless to say--everyone loves it.
Thanks for viewing. Hope I�ve passed back some of the inspiration and ambition to try a big project that I always get from you all.
