finishes for zebrawood
Ron Detz
>I am making kitchen countertops out of zebrawood. anyone have advice on finishes, or experience with this wood?
Ron Detz
Re: finishes for zebrawood
Sgian Dubh
>Crown cut shows yellow/red/orange and black blotching. In radially sawn wood the stripiness is due to alternating spiral grain, and the blotchiness in crown or radially cut material is due to the same growth pattern.
Okay to work in the solid, but you'll usually get tearout with every other stripe whichever way you feed it through machines. Often best taken to final dimension with thickness sanders, and usually best prepared for polishing using the following, or a mix of the following: power sanding, hand sanding and scraping.
As you work it, particularly with sanding machines, it smells pretty bad. Remove splinters immediately as they rapidly fester and balloon up, or at least they do with me.
Zebrawood seems a particularly strange choice for a kitchen countertop to me. Well, any solid wood seems a strange choice for this purpose in my eyes as it'll get a beating. I know people do it, and most go for an oil or water based varnish finish. They all seem to end up looking tatty in fairly short time scales, ie, a year to two years. Slainte.
What Sgian said
>I am one of those brave souls who is making wooden countertops as we speak. I've had them before and made them for customers in the old days. As Sgian mentioned, a solid varnish finish is probably your best combination of moisture and wear resistance. I'm using Minwax Helmsman spar urethane on my maple counters. In the past I have used Waterlox and it protects nicely against moisture and discoloration, but it isn't abrasion-resistant enough to hold up as well as a harder varnish to the constant abuse of food preparation.
Another note: One of the most important things you can do when making a wooden counter is to seal the edges of the sink cutout and the area over, under and around the sink area. I use boatbuilder's epoxy for this, making sure to get a thick continuous film. Also, be sure your sink opening leaves enough room for the top to contract during heating season. Otherwise, the wood can split, and as soon as moisture gets in there, your top is on the road to ruin.
Ellis- It would be great to see some
Alan Young
>picture documentation of your counter tops. Some of us may want to try this road less traveled...
Alan
Yeah, I should have...
>... been taking pictures, I guess, but as I found out in my magazine days, photographing a project while you build it just about doubles the amount of time it takes. I'm between coats of finish right now Alan, but I will take a few shots after the next coat and maybe show how I plan to assemble the parts.
Two roads diverged ...
| Sorry for the oblique reference to "The Road Less Traveled," Alan. That's one of the few poems I can recite by heart, a reminder of my years in New Hampshire.
I'll try to grab a shot of the cabinet-connector arrangement next time I go out there. ...Ellis Walentine, Host |
Thanks for those pictures Ellis...
Alan Young
>and the descriptions. My wife is talking about wood counter tops in our kitchen. That is some amazing Maple!
Alan
counter intuitive
Michael Dresdner
>I rather like zebra wood and used it extensively when I was in the guitar business. As for a counter top finish, I would suggest a good quality interior oil based polyurethane. There is no real advantage to using exterior or spar urethanes, and there is some disadvantage.
Check out...
>A one part clear water borne epoxy like Behr garage floor finish. It's easy to apply, water white, and tough. I used it on a wood sign that's been exposed to the weather for over 4 years, and there's no indication of deterioration. I also used it on the top of my shop storase cabinet, which is red oak T&G flooring. It's also a great sealer/finish for porous tile. Two coats on anything for a bullet proof finish.
Clint
