More on bugs in the wood, wood storage techniques
Bill Tindall, E.TN
>I don't know know about the propensity for bug infestation elsewhere, but here in E TN wood stored outside, or even inside at times, will become ruined by powder post beetle infestation. Having lost hundreds of dollars of lumber to these critters over the years, I don't dismiss their economic impact on my lumber piles.
Last night I took down a 1500 bd ft stack of mixed species I had assembled about 14 years ago. Lumber stored outside, sticked at 3/4" spacing, a foot off ground, covered with foot overhang. Lumber was sprayed with persistent insecticide before stacking. Both sides of lumber sprayed to wet the surface with sprayer I use for orchard.
The outside of the stack was discolored from where rain blows against the pile. Inside of the pile was bright. No bug damage or damage from weathering.
Fire wood stored near by, also covered and dry, is riddled with bug holes and bug dust.
There are several useful points to make. If the pile is well prepared lumber can be stored indefinitely out doors. At least here, the pile needs to be protected from rain and bugs to be successful.
Another less obvious point is this. Why am I storing this lumber that I have not needed the past 14 years and may not need for another 10 years? If you are serious about woodworking buy good lumber when you have the opportunity. Stored properly it always gains value and opportunity may only knock once in your life. If it knocks, seize it. There is lumber in this pile of a quality that will never be available again, especially the walnut and cherry.
You don't have to hang out at saw mills to find opportunity (but it does help). The first stash I ever bought came home on the roof of my VW bug from a retiring woodworker in Minneapolis. It was the best colored cherry I have ever seen.
