OT - Major appliance repair board
Glenn Madsen, SF Bay Area
>There's always an expert here, and sometimes three or five. So I ask.
We are the owners of a new Bosch dishwasher. A model SHE45M02 something or other. Installed professionally by Lowe's fellow, a contractor, I'm sure. He did a good job, and the device worked fine for three weeks or so.
Now, it seems not to be filling with water. The sink tap is running water, hot, so the line isn't crimped, or the tap turned off. It worked fine Saturday evening. Not so much so on Tuesday or Wednesday.
So I'm looking for the Woodcentral of appliance repair. A place where questions can be asked, dumb or not, and wisdom dispensed.
If anyone here has answers beyond what I get in the manual or at the company website, I'd be willing to consider those.
LOML isn't happy that her new dishwasher isn't filling with water at all.
Thanks in advance.
Re: OT - Major appliance repair board
Re: OT - Major appliance repair board *LINK*
John T
>Hi Glenn -
Can't actaully answer your question, but I've had great success with searching the Samurai Appliance Repair Forum - most of the time you can find your answer with a little searching, but registration is cheap, and well worth it, if you need to actually ask a question.
Good luck with your appliance quest.
-John-
>Thanks for that link, John. An interesting site. No joy on the fix yet, though. He did describe a diagnostic for a similar model that I'll have to try. Might work, shouldn't blow anything up.
Thanks!
>I will check that site out myself.
Clearly, if the unit is not filling, you need to check the supply to be sure there was not some trash or debris in the line that has stopped up or partially block the filler valve.
There is also some sort of switch that tells the unit when it is full. Some of them look like a small dome or plastic cup turned upside down. A float switch of sorts. Some of them move externally and you can see it. Some move internally and you can't see what it is doing. Clean that so it can work properly.
One other thought. It does not have some sort of water saver setting does it? Like for small or light loads. Hasn't gotten set to water saver has it.
del schisler
>what kind of fill line going to unit ? Hope he didn't put a water saver line If so it has to be removed at the end going into the dish washer It will have a chrome looking piece on it A new thing for the water inputs for fausets and maybe they have one for dish wahers?? what it does is shut off the water flow when their is a big leek It may have just went bad and doesn't know their is no leek?? Just a thought They are fairley new items Not that good i here
Ray, SW Ohio
>had the same problem, turned out to be the float, my 2�
Jay St. Peter - Southern, MD
>The float in mine is in the unit itself and can get knocked out if you drag something across the bottom from the lower rack. The unit won't fill until it's put back in place.
Ken Krawford
>I know this seems kind of obvious, but if the unit is that new and a Lowe's contractor installed it, why not call them? This should be a warranty issue one way or the other.
GolfSteve in Calgary
>Hi Glenn,
I have an older Bosch dishwasher (SHMC3400 ??), about 13 years old. It recently stopped filling with water. Turned out that the water fill solenoid valve went bad. $65 for a new part and an afternoon of troubleshooting and I was back in service.
Yours is still new. No warranty?
Cheers,
Steven
Re: OT - Thanks, guys!
>I fought with the look around poke at this diagnostics for about an hour and a half, then called the 800 number. The factory guy is due here on Monday morning.
For a long time, I wouldn't buy the additional service agreement on certain items. The extra $99 from Lowes on these seems really cheap insurance for me now, and so goes on every major appliance. Not a fan of climbing around under the sink. Never really was.
I appreciate your comments, all, and will see if I can find the float in the dishwasher space, without pulling the unit.
>The Bosch factory guy is due here Monday morning to see what the problem is. So far, the biggest challenge is going to be waiting for him.
Thanks!
Re: OT - So he came by, and fixed it.
>There was a leak in a hose, caused by some sort of crimp. 20 minutes of fussing around, and it works just fine. The leak caused the float problem someone mentioned, which caused the 'no fill' situation.
LOML now knows how the system is supposed to work, and I know how to fix it so it works until he can come back, should it ever happen again, which we don't expect.
Thanks, all, for the assist!
