Penn State table saw dust guard *LINK*
Rob Ring
>Has anybody had experience with the PSI table saw dust guard (see link)? How does it compare to the pricier Exactor? http://www.amazon.com/exec/obidos/tg/detail/-/B000EZXYWM/ref=pd_luc_mri?%5Fencoding=UTF8&m=ATVPDKIKX0DER&v=glance
PSI guard
Re: Penn State table saw dust guard *LINK*
RickS
>I have this TS Guard. As with everything it has its good and bad. I like it way better than the factory supplied guard. It does a fair job with dust collection (PSI 2.5HP cyclone) while ripping. I put a line of tape on the hinged front flap so that it drags on the wood. The flap as delivered was allowing debris to shoot under it defeating the dust collection. When ripping anything less than about 1 inch wide the guard must be moved out of the way or some other type of hold-down/push-thru method needs to be applied. When crosscutting, my crosscut support bar(which stands about 3 inches tall) pushes the guard up high enough that dust is no longer collected. I could move the crosscut bar further away from the blade but that means less support close to the blade, and I could move the left side of the guard closer to the left side of the blade, but I want the extra room for safety, so I just deal. It is not the easiest to move out of the way for tall operations like cutting tenons on end. Since it sits in the middle of the table, you have to reach and lift to slide it out of the way and this can be hard on some peoples backs. (I have seen some with a crank to move the head but they cost way more. So I just deal.) As far as safety goes, It seems like it would take a pretty good bit of force to push it from the side to get to the blade, so if the blade is centered in the guard you have a good bit of room before the guard would come close to the blade. (I haven't tried to force the thing there but it is pretty sturdy). It would take massive force to get through the guard to the blade from the top. Overall. I like it.
Rob Ring
>Thanks for the feedback, Rick.
