Good News, and Bad News
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I used to suffer from some of these symptoms to, but they are not so bad now. Before when I would start a walnut project, I would initially just love the smell, then next would come the spike up the nose sensation as the sneezing started.
But as I have grown older, and the wear and tear of working, playing and loving too hard has finally caught up with me, and the aches and pains of living hard and fast have finally come into finer focus, I have come to the realization that some of the things that once bothered me are not as bad as they once were.
I think the body is only capable of feeling its top most pains on the scale. This is probably part of the principal of acupuncture, acupressure, and myotherapy etc. Those involve short circuiting the body's wiring system, while my observation is more akin to sensory overload.
If you are not getting the relief from whatever drugs you take to help you get past those irritating symptoms, you should follow my advice. If whenever you go out into the shop, and start sanding walnut, and you nose starts to twitch, just stop sanding long enough to find a hammer and choose the least need finger on either hand. Lay that finger out on a good solid surface and give the nail a good solid whack with the hammer, and you can bet that you nose will stop itching for the rest of the night.
Note: There is a side effect, that your eyes may water a little, but that is part of the benefit, in that your tear-ducts starve, or cheat your sinuses of fluids which only add to that other disgusting drippy nose symptom.
At the end of the evening when you go into the house, and your wife ask you how was your night, did the walnut bother you? Look her right in the eye, pull her in close and give her a kiss on the mouth, and thank her for asking, but answer no, while you conceal the swollen finger.
Which leads me to remember reading Aristotle observed that feeling, and emotions like joy and pain are not opposite ends of a spectrum. Rather than a straight line, they are side by side at the bottom of a circle. Thus laugh until I cried when happy, or feeling the urge to laugh when feeling extreme pain. So when you kiss your wife, consider that extreme pleasure will cancel other annoying distracting symptoms also.
And the really good news is that you can sacrifice the same finger time and time again, without having to choose a new one each time. ;-) K
Disclaimer: Keep in mind that some of this advice is exactly worth what you have paid for it, which is nothing, so proceed at your own risk.
