support for box lid
Wayne Carson
>need a suggestion on a lid retention device for a jewelry box lid. Sides are only 3/8" thick top is 3/4". Would like it to open just over 90.
support for box lid
Wayne Carson
Re: support for box lid *LINK*
Bob Entwisle in NJ
>Maybe stop hinges, LV has some and I'm sure there are others
http://www.leevalley.com/hardware/page.aspx?c=2&p=46492&cat=3,41241,41245&ap=1
charlie belden
>The link points to what appear to be "piano" hinges which are "formed" sheet stock rather than "cast and machined". As a result, the "formed" hinge "leaves" don't close completely.
leaving a gap between lid and box. You can
get the lid to close flush with the top of the box but only if you mortise both lid and box for the hinge deeper than just the thickness of the leaves. But that looks "not right" the face of each leaf will obviously be below the adjacent wood.
BUT - if you crimp the hinge - say in a vise, you can get around that "challenge".
If this type of hinge opens to at least 180 degrees, getting the screws in the right places so the lid will close both against the top of the side AND aligned precisely to it (no overlap / underlap) is semi-tricky - but a LOT easier than getting the same results when the hinge only opens to 90 to 110 degrees.
Might consider "slot hinges". The bevel angle you choose for the outside edge of the lid and box lip determine how far the hinge will open.
pecker
>I used these stop hinges from Rockler on a fairly substantial box lid.
They open to 95 degrees and keep the lid from falling shut.
http://www.rockler.com/product.cfm?page=9833
Jim Dillon
>Wayne,
Here are a couple of sources that I have used.
Tools for Working Wood:
http://www.toolsforworkingwood.com/Merchant/merchant.mvc
Beall Tool Company
http://www.bealltool.com/products/hardware/
But your basic problem is that your sides are only 3/8 inch wide whereas the small size Brusso quadrant hinge is 5/16 inch wide which doesn't give you a lot of room to safely install the hinge. I have the Beall Quadrant hinge but am not at my shop right now to measure how wide it is. You might consider the box hinges with the built-in stop. They work well for small lids if the screws are well-set.
Note that Brusso also makes a lid support that is 1/4 inch wide (small size) and is easier to install than a quadrant hinge. Might be worth a try. I think you also need an ordinary hinge(s) on the back of the box to pivot the lid. Oh yes, Quadrant hinges are very fussy to install - at least in my clumsy hands. Hope this helps.
Jim
del schisler
>this is the cheepest place to get hinges I make jewelery box's I order 100 at a time and screws 1000 at a time cost 18 cents each for 3/4" x 2" hinge my size they have hunded of size's 1000 screws cost 1 penny each #2 x 3/8" round phillips head best price i have found Check it over lot's of items
http://www.craft-inc.com/prod_list.aspx?riIDClass=10&riPageID=25
Lee Schierer - McKean, PA
>I used these small brass cylinder hinges available from Rockler
and other sources for the top and doors of the jewelry box I made for my wife.
My only concern would be the thickness you plan for your top, you might want more than just two hinges. If you cut the bevel at slightly more than 45 degrees the lid will stay open.
Lee
James Clair
>Have you thought about brass chain? Low cost at most Ture Value Stores. Small brass eyes and what ever length of chain you need.
