Quasi-tragedy with walnut tree - need suggestions
Duncan of Cincinnati
>So, one my wife's coworkers has a beautiful walnut tree in their front yard. Long story short, they are sick of the droppings and cut it down. To my disbelief they split it into firewood -- this was a ~30" dia. tree with a main trunk height of around 50'. If I had known he was going to split it I would have definitely talked him out of it and had it cut into boards by a mill. Would have made (a few) very nice dining room table(s). Not to mention that, were there a buyer, he is passing up a bunch of $$$. It is still, even in its split form, beautiful, aromatic wood. Just gorgeous stuff. That the bummer part.
The good part of this story is that he wound up with more wood than he could handle, so I have ~1/2 face chord of the stuff sitting in my back yard right now. :-) !!!
Here is where I need your suggestions: there are a good number of pieces that are approximately 24"x3"x3", and other useable shapes, all with no end splits that could easily be trimmed up on the saw. Most are rectangular, some triangular, etc., the usual split wood sizes and shapes. WHAT WOULD YOU MAKE WITH THESE? I'm looking for ideas to fill my summer shop time. Please help!
(PS: I don't turn; strictly the flat stuff) Thanks!!
Re: Quasi-tragedy with walnut tree - need suggestions
steve mackay
>Frames and boxes of assorted sizes come to mind but . . . dare I say it ? At 24x3x3 all you'd need is a sheet of same-same ply and you might have a killer tool chest or two !
>Custom picture frames came to mind, too. I especially like the box idea as that would supply a lot of Christmas presents ;)
Thanks for the input.
Bill Tindall, E.TN
>While I am not an advocate of end coating lumber ( in my hands it isn't worth the effort) in this case end coating is essential, and it needs to be quick to be effective. In a firewood stack the ends are going to dry quickly and check. A 2" check on each end of a 24" piece is a problem.
It can be a dangerous job trying to turn firewood into boards. Be sure the pieces are held down securely while sawing.
turning squares
>Duncan,
I had a similar experience, but managed to stop the neighbor before the entire trunk was cut into firewood lengths and before any of it was split. I got enough to feed my sawmill and turn some large bowls.
The size you have suggests turning wood whether or not you turn it yourself. There should be a market for 3x3 walnut especially if you process it into turning squares in lengths to pack into a flat rate USPS box. (This is easy with a bandsaw.) Lots of turners buy, sell, and trade wood this way since the shipping cost is reasonable. 3x3 is a very useful size, perfect for boxes, vases, pepper grinders, and smaller items.
You might ask on the Turning board to judge the interest to see if it would be worth your effort.
BTW, I made the gavels in the photo from walnut turning squares a little smaller than 3x3. That tree was also cut for firewood.
Can you say resaw?
Lee Schierer - McKean, PA
>Those pieces are large enough to resaw into useable boards for small projects. I received some similar pieces from Domonic Greco and made this:
Lee
Re: turning squares
Don at Central Illinois
>Learn to turn. They are the right size for Chrismas ornaments. Or as John said, trade or sell to turners.
