OT Question on Bifocal eyeglasses.
>I'm in line for a new pair of glasses. (Not a candidate for any of the surgeries.)
I have the No-Line bifocals and they are pretty old. I have heard that the technology has improved. A wider, better viewing area for the reading part. Anyone have any info and specific brands?
Re: OT Question on Bifocal eyeglasses.
Howard Norman
>I have been wearing no line glasses for many years now Barry. I believe that they have improved somewhat over the years. However there are significant deferences between brands. The last time I checked into the brands Verilux was the gold standard. I am not currently wearing Verilux because of the cost. I have purchased my last two pairs of glasses at Costco.
h
You've Got to Draw The Line Somewhere
>Good Evening Barry,
My bifocals have lines. One of my early didn't, and I couldn't figure out my bearings. I was in travel status, and pulled an embarrassing "Jerry Ford" coming down the passenger ramp. That was enough for me to forsake those new fangled bifocals in favor of the older kind. After all, You've got to draw the line somewhere. No problems, even with vanity, since. :<)
George
Bill Roland (Mt Juliet,TN)
>I tried the no lines a couple of years ago and had to take them back. I have to read electronic schematics and the sweetspot was so narrow I almost went nuts. Maybe you can use them depending what you need them for.
Larry Clinton At Frankfort (Central)., Indiana
>I have the graduated lens, have used them for several years. Took me a little time with the first pair - tended to put weight on my foot while it was about 3 ~ 6" above the next stair step. Now they give me absolutely no problems. As I still like target shooting these lens let me sight in targets and sights much better than the "line" style. As an Engineer, I found these to be much better when working on blueprints, cad and machinery. I believe my lenses are Verilux. I always have the "hard scratch resistant coating" applied. Think I paid about $300 for the last (lenses only) pair this year.
Ralph Turney
>They're called progressive lenses. I had them for about 8 years until I had Lasic a few months ago. They did take a few days to get used to, but once I did they worked fine.
I wear line free bifocals
Lee Schierer - McKean, PA
>A number of years ago, I noticed that i was having trouble seeing at intermediate distances, particularly when reading blue prints at work and woodworking at home. I spoke with my Opthomologist and he suggested that tri focals were just what I needed. I felt that tri focals were not for me so I asked about options. Then he offered a Zeiss Gradal lense with a wide upper view area and largest transition focus area and lower bifoacl area of any lense available at the time. However, he wasn't sure I could adapt after having worn bifocals for so many years. In checking, we discovered that Zeiss will replace the graduated lenses with any other lense if you are unhappy with them at no charge. It took me less than a week to adapt.
I tried them, I love them. I will never go back to lined lenses. I'm now on my second pair. This past winter my wife also switched after complaining about not being able to see with her discount house lenses for nearly 2 years. After about 2 weeks with the new lenses, she stopped complaining she couldn't see with her glasses. I've also noticed that she is reading more.
The progressive lense also helps when working on the computer. The only down side is retraining yourself to tilt your head up or down slightly to get perfect focus and to turn your head instead of moving your eyes to see things off to the side.
The Zeiss lenses are more expensive than some of the other progressives, but in my opinion this is truly a case where you get what you pay for.
Lee
Carol - now in NC Nebraska
>I have Verilux tri-focals and have had them for years. Once I went cheap and got a house brand. Big difference. Went back to Verilux, so they turned out to be less expensive in the long run. When it comes to my eyes, I've decided to be blind to the price.
Back when I had to go to bi-focals, I tried the lined variety. Yikes! I thought, hey, if I have to make an adjustment to multiple focal lenses anyway, I'm going without the lines.
It only takes a little while to adjust. Now I don't know what I would do without them.
BrianA
>I have not worn bi-focal yet. I am thinking of getting a pair of progressive just to try them. I have purchased a couple of pair of regular prescription and prescription sunglasses at this place. I was happy with what I got. They are so cheap that it may be worth trying a pair of bi focal just to see how you like it. My glasses frames and lenses were around $12 plus $5 freight. Progressive are more, but still way cheaper than all other places.
zennioptical.com
Hamish
>I have tried progresive lenses and could not get on with them. They cut your field of vision right down to just the centre of the glasses, requiring you to move your head rather than your eyes to see sideways. Counterproductive in my mind. So I went back to lined bifocals and had the position of the bifocal moved up the frame to nearly half way, which gives me more of a field of vision when I am woodworking etc. The top half of the lens stays the same as if they were normal mono focal glasses, ie a full field of vision, and means that I can move and exercise my eyes as it should be.
Jesper, Denmark
Jesper, Denmark
>I have just gone through a selection process like all new glasses. I have always been using bifocals with the line. I could never get used to the other kind.
One of the things you need to know is that there are different sizes availablke for the reading part and that you can choose how high the line is on the glasses. I have gone with two different sets: One foe indoors, optimized for the PC through the top and reading through the bottom. They are just fine for moving around the house and for turning etc.
The other set is for outside, which means optimizing for long distance with the reading part optimized for the distance to the car instruments. In both sets, the dividing line is higher than the optician would normally recommend, so I get a larger reading field, and the line is right at the bottom of the windshield when driving.
My eyes are different -6.5 on one and - 4.0 on the oher.
Alan Schwabacher
>I don't know the brand that I have, but can say that progressive bifocals are DEFINITELY not all the same. I got some from one of the inexpensive places that were unwearable, making me trip on everything, so I returned them and went to a good optician. I paid a heck of a lot more, and got some that were enormously better. There was no disorientation from the first time I put them on, and the near focus area of the lens must be wider.
Sorry I can't be more specific, but I think most of the very real complaints about progressives apply only to some types. (I am pretty analytical, and it pains me to not be able to explain the difference. But it is very real.)
It is still frustrating to work on something close and overhead. Bifocal safety glasses worn upside down help for that. The stick-on bifocal lenses are not good enough to help much.
Tom MacGregor
>I have "occupational bifocals" with magnification top and bottom because I often have to do close work looking upwards. It made a large lens necessary, but they're OSHA approved safety glasses and I like the amount of area they cover when I'm working.
That reminds me of the following definition that I'm sure some of you will appreciate:
OSHA: A protective coating made of a half-baked mixture of split hairs, baloney and red tape applied at random with a shotgun.
Re: I wear line free bifocals
Fred Davis
>Lee,
I wear bifocals all day and when I sit down to the computer I use a pair of glasses I had a optician do for me.
all they are is a old set of my glass frames fitted with the entire lense ground to my bifocal numbers, no head tilting now.
FredD
