ADVERTISE HERE - FREE TRIAL
Sharpening
Sharpening
Sharpening
David Ragan
>Hello,
Thanks for your help with the table apron. I made it from poplar, and bought the very accurate JessEm miter guage, made the octagonal sides at exactly 67.5 degrees, they fit perfectly.
Here's my next question. How to best sharpen my mortise chisels. At Woodcraft, they showed me their sharpening set, for the inside of the of the rectangular mortise chisel. I do know that on all drill bits, you sharpen the inside surfaces, so you don't diminish the profile the drill cuts out of the wood.
What tools do you use to sharpen the mortising chisel and the drill bit inside of it?
Thanks, David
Re: Sharpening
Re: Sharpening *LINK*
Hank Knight
>David,
I assume you are talking about sharpening hollow chisels used with a power mortiser or drill press attachment. If so, polish the outside faces with regular flat fine grit stones. For the inside bevels, here is what you are looking for:
Sharpening Cones
