Any wood boat experts out there?
Pete in Holland, MI
>Working on a wooden water tank (built in classic wood barrel construction techniques) and need to install a threaded pipe "insert" into the tank to allow installation of a National Pipe Thread (NPT) valve. Planning on either 1" or 1-1/4".
Have been looking at nautical thru-hull fittings. Is this the way to go, or are there other proven techniques? Wood tank thickness is 1-3/4". How to I seal such a thing?
Need to do something more than using a wood valve driven into a hole.
All advice welcome.
Thanx !
Pete
Re: Any wood boat experts out there?
ebd
ebd
>I'd use a through the hull fitting and seal it with Marine Goop (that's the actual name). If you can't find the Marine Goop, Shoe Goo, Outdoorsman Goop, etc all work the same. The goop hardens and clings increadibly and has some flexibility when hard. I use it to seal the rivets on my aluminum boat and it works great (no leaks) even under those demanding conditions year after year.
