6" to 4" adaptor for ducting
WarrenC
>where can I find a 6"-4" adapter. I'm running 6" PVC to all my machines, but my band saw only has 4" ports.
thanks
WarrenC
thanks
Re: 6" to 4" adaptor for ducting
Jay St. Peter - SoMD
>Get 'em at the borg. Just use metal ductwork adapters. If you're adapting from a straight run of PVC, you need a crimping tool to crimp the 6" end. Then shove it into the PVC and screw it in with some sheet metal screws. A little Al tape and it's all sealed up. If you're adapting from a fitting, wrap the 6" end with a little window sealing foam and shove it into the PVC fitting. Then screw and tape. The borg near me also sells 6-6-4 wyes you can use to adapt to 4" PVC.
Jay
Re: Fernco
Kneale Brownson Dreaming of the Snow in N. MI
>You can get Fernco-style flexible adapters that seal with a hose clamp at most good hardware sources or plumbing specific outlets. Made for use with plastics.
Make a wooden one
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I have made several wooden ones by simply cutting a circle with a small tapper on the outside to make it easier to slip into the larger pipe. Then just saw a hole in the middle for whatever size you need for the smaller hose / pipe.
You should be able to do this faster than you can get your car out of the driveway for no $.
Larry Clinton At Frankfort (Central)., Indiana
>Hope your using S&W pvc. I did my (30 x 30 foot) shop duct system in S&W pvc - It is about 50% or less than the cost of regular (water pressure type) pvc. The S&W fittings will not fit the standard PVC as the PVC wall on the pressure style is thicker. The adapter fitting has even a greater pricing difference. I purchased most of my 6" to 4" adapters at the borgs. Either Menards or Lowes. The real oddballs I purchased at a plumbing supply house. One fitting, an 8" to 6" x 6" Y fitting, I fabricated from 8" and 6" tubing and pvc cement. I did this as the cheapest method I could find to make this transition was more than $125. I made the fitting for less than $15 - and 3~4 hours fiddling around. I used bell (female 6" to female 4") adapters to convert to 4" then a short section of 4" pipe to the plastic blast gate. Another short section of 4" in the gate then allows the flex 4" to be slipped over the pipe and clamped.
WarrenC
>Keith,
I like your idea. Thank you
OT. Kneale, missing snow already?
Gary Camp, Bend, Oregon
>I will give you some of mine, we just dropped down to 10 feet yesterday. One more week of skiing, then we close till summer sightseeing.
glc (a little tired of winter)
>Warren,
I got my 6>4 reducers from a plumbing supply because they use a tapered bell rather than the blunt "hole in a flat" kind of thing that are sold by Lowe's. I think they're better for the air flow with less turbulance in the duct. Just make sure you ask for the lighter weight S&D stuff. Price was about the same.
BTW don't glue your sections together, but rather tape seal them with the aluminum HVAC tape. Seals the joints but makes things easy to separate in case you have to open the ducts for cleaning.
Kevin Mac Luskie
>McMaster-Carr has them. (http://www.mcmaster.com/)
Part Number: 9102K264
$9.69 each.
Re: OT. Kneale, missing snow already?
>Yeah, my last day here was April 19. Pretty marginal mushy conditions, but I got in a couple hours to make it Day 134 for the season.
