glue
Bill Arthur
>What type of glue should I use to rejoin the planks in a maple top table that I am going ot restain? I was thinking of Gorila Glue - what do you think?
glue
Bill Arthur
Re: glue
>Read the article in Fine Woodworking on glues. Gorilla Glue did not score very high in the strength department.
Personally, I don't like the glue lines that I've gotten with Gorilla Glue.
Re: glue
Dan Donaldson
>If it is not for outdoor use, I would use hide glue or titebond.
Remove the old glue first and re-joint if necessar
use Titebond 3- waterproof & works well
Chicago Bob
Why!
Bill Tindall, E.TN
>Why is there any question about what glue to use on interior wood joints? For some purposes I can understand why some people use hide glue. But the furniture industry, with its hordes of engineers to study these things, and university wood science departments that confirm the results, have determined that plain vanilla yellow glue is best for interior wood joints. Thin with 5% water to slow set time for joints like M&T. Hide and yellow glue have successfully assembled 99.999999+% of the world's furniture during the last 1000 years. Stick with one or the other and you won't be experimenting with your joints or paying more than you need to.
Re: I partially agree with you Bill - but
Larry Clinton At Frankfort (Central)., Indiana
>often the method or material used in industry is not the best for home use. In this case I really believe you are right - although I like hide glue for furniture as it is reversible, easily re-glued and doesn't leave visible glue lines AND has a few thousand years of testing with pretty excellent results. I also use Titebond 3 for other applications (It is cheaper/easier for me to have one glue in a gallon jug than many specialized ones in small containers). I a retired Engineer (production / manufacturing for 30+ years / Quality for 8+ years). Our industry was not involved in woodworking but did use many adhesives - epoxies and coatings (spray, dip, brush). Often the criteria used in our processes were not relevant in a home shop environment. IE: I may have chosen a coating that would cure very rapidly in a heated oven or UV light or with steam injected ovens. This would be done to improve our process, not the product. Repair ability or reversibility may not be an issue to a furniture manufacturer, but may be very important to a hobbyist. We may have chosen a coating based on testing that indicated a cheaper one, while not the best, would meet the criteria we needed to insure the product would meet the customer needs at the lowest cost and highest profit. If your using a few thousand gallon of product a few cents a gallon adds up rapidly. Glue line visibility may not be an issue if you have hydraulic clamps and are using a glaze on all your products. This is not saying the industry is wrong - just that they may not want or need exactly the same materials a small shop will use to get the results they want/need.
