Re: OT--AVG 8.0
Curly Smith
>1. Set a system restore point. Don't know what this means or how to go about it.
Click "Start | All Programs | Accessories | System Tools | System Restore" to open the utility
Make sure System Restore is active:
Click "System Restore Settings" on the left side of the screen
You'll get a "System Properties" box, and you should be on the "System Restore" tab
make sure the box "Turn off System Restore on all drives" is NOT checked, then click OK to close the box
Then to set a restore point:
Click the "Create a restore point" box, Click Next, Enter a useful description (like "before installing xxx", or "uninstalled AVG, preparing to edit registry" -- date and time are added but it helps to have a description of why you added the restore point), Click Create. Click Close after the restore point has been created.
2. Do I "export a copy" of the registry by saving it to a CD, a floppy or something else like one of those flash drive thingies?
3. "remember the directory" Does this refer to the "name that defines this event"?
The registry is a database and the term "export" simply means that you'll be copying data from the database to an external file. If things go awry then you can later "import" the data from the file back into the database. Regedit is a utility that allows you to manipulate/modify the registry database.
You should save the registry file that you export on your C: drive. You'll get a text box when you click "export" and you'll have the opportunity to enter a file name. If you export multiple copies of the registry it helps to have a good description of why you exported it (the same as in the above restore point) in case you later need to import the file. You can rely on the date/time stamp and your notes but I prefer to include my notes in the filename. The export utility will have a default directory, generally "My Documents", but it's advisable to note where the file is stored in case the defaults are lost.
4. Upon restart, I'm supposed to "close all programs". Is this like exiting all the items on the taskbar? Is there somewhere else I can find a list of all running programs?
Close all programs running in the taskbar. Close any other shortcut bars or menu bars that you might have running. Note that this will close your firewall so make sure that you don't connect to the internet without rebooting (the AVG install requires a reboot to finish the install anyway so this shouldn't be an issue). Almost all programs carry the warning "It's strongly advised to close all programs be installing this program" but 99.99% of the time it's unnecessary. This might be the 0.01% of the time that it's necessary.
