dust collection on portable power tools
RobRing
>I'm trying to improve the dust collection on a few portable power tools but I'm having problems fitting my shop-vac hose to the tool dust ports. Most of the dust ports are 1 1/2" OD (Makita SCMS, DW plunge router, DW biscuit jointer), and one is 1 1/4" OD (Bosch belt sander). My 1 1/4" shop vac hose doesn't fit snugly inside the 1 1/2" OD ports and is the same size as the belt sander port. All the adaptors I've found are either 1 1/2" OD or 1 1/4" OD. I've even tried finding a 1 1/2" ID coupler and struck out. Any suggestions?
As a slightly more complicated issue, I'm also trying to rig some sort of dust collection to my low-end DW circ saw, which has no dust port. Has anybody done this successfully? I thought of cutting a hole i the retractable guard and mounting some type of small-diameter PVC flange as a dust port but i haven't found a suitable fitting for this.
Thanks for any help!
Rob
Re: dust collection on portable power tools
Dave Bair, Eaton Rapids, MI
>I attach my Fein collector to my tools using an innertube-like adapter that I found at my local wood vendor. It stretches enough to go over most large ports and the vac's hose, though I had to cut and taper one to fit my PC sanders. I can't remember if it's made by Fein.
Chuck in ND
>I think if you go to a hardware store you should be able to find rubber adapters that will fit. Look in the plumbing section, they have radiator clamps on both ends. Plumbers call them Fernco fittings.
RobRing
>I was at home depot last night looking at PVC couplings and saw the fernco fittings - I said "hmm, that may work" grabbed a few pvc couplings instead (for a few pennies each). Of course, none of them fit. I'll give it a whirl...
>I have a fitting which works - but I can't remember where I got it :). As I recall, it actually came with a hose adapter for my Delta 14" band saw. It fits into the dust port of my Dewalt Plunge Router.
Highland Woodworking (Hardware) sells an "adjustable" (cut at the correct diameter) fitting for ~$5.
>I bought a replacement hose kit for a shop vac at Lowes. Came with a black hose and a short "wand" attached and some other adapter type fittings. The wand part is tapered. It fits perfectly on my PC 333 ROS and I sometimes use it as a long handle. I just use one of the standard adapters to fit the small hose into my DC hose. I believe you could also trim that wand off to different lengths and get different sized connections. Of course, you would have to have more than one, but they were cheap.
Ed Mulligan, Cape Cod
>Rob
See if you can borrow someone's Festool hose for a test drive. I have one. It's green and expensive but it fits my Fein vac and all of my portable tools I've tried it on. It is far more flexible than other hoses I've tried. I see the flex as a major advantage for error-free operation.
For effective dust pickup with the circular saw, I think you would have to enclose the blade like Festool does. Or just buy the Festool saw. That's what I did. The cost pain only lasted until I made my first cut :)
Ed
