Cedar for furniture?
Dan Mitchell
>Awhile back I removed a hot tub which had a base made of 1x3.5" cedar boards of various lengths. I'm using some of them to replace some rotten cedar plank siding on the exterior of the sun room where the hot tub was located, exposed when I removed a deck (it's a regular demolition site around here... ) Since the existing siding is only 3/4" thick, I am needing to plane these hot tub boards down 1/4". After running them through the planer (love that smell!), the grain looks really beautiful, almost like cherry in some instances. Since I have a bunch of this, I'm wondering if it might be good to hone my furniture making skills (now nonexistent, for all intents & purposes) and make a small table or something similar. But of course, the cedar is much softer than cherry, and I don't know what finish might be best (if any) to retain this beautiful grain. The "weathered gray" look is good for the outdoors, but for inside I'd really like to retain the cherry-look. Any ideas, or is this wood only really suitable for siding and such?
Dan
Re: Cedar for furniture?
Nat Robison
>I was wondering the same thing recently.....whether cedar is suitable for indoor furniture.
I applied some Zinsser Amber Shellac to a piece of cedar recently and loved the color. I was considering making a TV stand from cedar. I've never used or finished cherry but the color makes me think of cherry somewhat.
I assume that cedar will ding and dent quicker than harder woods but maybe finishing with poly would help delay distressing.
>Good Afternoon Dan,
Cedar chests are furniture, and many homnes have them. I suggest you build one of them first. I built one for my wife, and it is solid cedar rather than cedar lined. While it is soft, the wood's application as a storage chest minimizes exposure to wear and tare. My finish was simply
Seal coat shellac top coated with several applications of wiping poly. See Shop Shot #746
George
Dan Mitchell
>Thanks for the replies & Nat for the pic. A cedar chest is an interesting idea. My mother had one my father had bought her, Lane as I recall, cedar lined.
Dan
John McGaw
>We probably need to clarify what sort of "cedar" you are dealing with. There is cedar and then there is cedar. What many people are referring to when they use the term isn't even cedar -- "aromatic" cedar is really a juniper (this is what is used to line closets and chests). It is a bit difficult to finish since it contains chemicals which leave some film-forming finishing materials gummy. The other sort of "cedar" most commonly seen in North America is white cedar and red cedar, both of which are actually members of the cypress family. Same thing with Alaska yellow cedar.
Dan Mitchell
>Interesting. I can tell you it smells like pencil shavings when you plane it, if that narrows it down any. Some of the boards are that deep red, like the pic Nat posted, some almost pinkish, others are more the color of pine in areas. After working a bit of it, it really is VERY soft though, and just off hand feels a bit lighter in weight than pine. Probably too soft for furniture use. Maybe I'll see if I can find some cheap poplar to "practice on".
Thanks for the reply.
Dan
Larry Clinton At Frankfort (Central)., Indiana
>The picture posted appears to be "Western red Cedar". From your description I would guess you have the Western variety. (The eastern aromatic cedar is normally filled with knots, has a mix of cream or white sapwood and deep red heartwood with fairly "wild" grain and pattern. IMHO all cedar chests are constructed using Eastern Red Aromatic cedar. (I do believe that it is Juniper). The Aromatic cedar is much harder than the Western. I just finished a blanket chest of White Oak with an aromatic cedar inside. I also built a bookcase from the Eastern aromatic cedar in about 1957 - my mother used it until she passed on - now my second son has it in use in his home. It was finished with Sherwin Williams "Beautylock", a type of varnish no longer available (at least under that name). It has held up wonderfully and although the finish did yellow slightly it still looks pretty good. I have never seen anything used indoors build with western red cedar. All the outdoor projects requiring any structural strength I have seen using it were build with 2" thick lumber, as the wood is fairly weak as well as being soft. It does make nice birdhouses and window planter boxes.
