>I'm going to make a small, round, bar-height table for my billiards room. This will be around 24" in diameter and at bar height so you can stand at it or sit on bar-height stools. I already know that I'm going to use some extra maple butcher block as the top piece.
Does anyone have any ideas or a good plan for a base for this type of table? I have entertained a couple different ideas from just a 3" pipe with threaded flanges at the top and bottom to an elaborate wood structure. If possible, it would be nice to design something with a place to rest your feet if you're sitting on a stool. Any ideas or examples are welcome and appreciated.
>A 2' diameter piece of butcher block could ruin someone's whole day if it falls over on them. If you go to restaurants or bars that have tables like these, I think you will find a trumpet shaped base made of cast iron or steel, possibly filled with concrete(?). All I know is that they are very heavy and have very low centers of gravity.
This is not to say you couldn't turn a trumpet-shaped base and a tenoned hardwood post to go from there to the top. If you do, see if you can get what is called a "loader," a round, flat piece of cast iron that is made for lamp bases. I don't know if you can get loaders larger than that, but I'll bet a flywheel from a junkyard would do the trick.
As far as a foot rest, they make regular brass brackets to support 2" brass tubing. Maybe you could install three of these around the base (or make custom supports from wood, maybe dovetailed into the base) and have a local fabricator bend some pipe to the exact diameter you need. They have large bending rolls for this kind of work. Or, staying with the lathe theme, turn what amounts to a big wooden steering wheel and mount that on your supports.
