Bent 1" bandsaw blade
Dean Lapinel
>I thought it would snap from heat treatment but the blade bent for about 2" of length. Is this something that can be hammered back straight or not so simple?
Re: Bent 1" bandsaw blade
>I don't like using bandsaw blades with kinks. IMHO, they are an accident waiting to happen and they might possible damage your tires, thrust bearings, alignment blocks (or bearings). I have "salvaged" portions of the blades for use in a bow saw and for other purposes.
>Good Afternoon Dean,
I've tried to unkink a 3/4" band and did get it to work. However, it thumped and jumped against the guides and bearings, and did a generally lousey job sawing. JL is right. Get yourself another band.
George
Ken Oakley-Sunny St. Cloud, Fla
>I have made some nice knife blades and scrapers with bent or broken bandsaw blades. Makes great filet knives if you are a fisherman. Might be good for skinning also if you are a hunter.
Dean Lapinel
>Guess I know what to do with three good answers like this. Scrapers and knives !
Check to see if there is a local Metal or
Art Silva
>Machine Shop that can shear/saw the blade cleanly on both sides of the bend and have it rewelded. There should be enough of an adjustment range on your saw to compensate for the small amount removed. Good luck. Art
