Salad Bowl Finish Recipe ????
Warren Chernoff
>Is is possible to make your own salsd bowl finish. I know it's a wiping varnish, but are there any other "special" ingredients. Around where I live, the cost of salad bowl finish is astronomical.
Warren Chernoff
Re: Salad Bowl Finish Recipe ????
Tom Pilsbury (Chicago)
>I use walnut oil. Works fine. You can also use mineral oil obtained at the drugstore.
>Warren,
Over the years I've read several articles explaining why it is unnecessary to use a special salad bowl finish. The one I read recently in a major woodworking or turning magazine suggested that special salad bowl finishes are a waste of money.
The gist of the articles is always that once the finish is completely dry, any penetrating finish is "food safe".
Re: Salad Bowl Finish Recipe ???? *LINK*
David Yoho
>Warren, I think you will find answers to your questions by viewing the You Tube video by Charles Neil on cutting board finishes. You may be surprised to learn the choices you have and those to stay away from and why. You'll hear what a salad bowl finish should do and how to apply it.
Check the link below -
Sean Troy
>Mike Mahoney has some good info on his site.
http://www.bowlmakerinc.com/
Sources
Bill Howatt
>I use mineral oil for some finishing, as a sanding medium and sometimes as an aid for cutting obstinate end-grain.
I find that Wal-Mart is cheaper than the drug-store and if you want to get a larger quantity at a cheap price, try a animal feed store. It is used to treat some livestock internal problems. Unlike some other "finishing" chemicals it won't go bad sitting around the shop.
Bill
The dirty little secret
Deep Throat
>Here's the dirty little secret:
Virtually all finishes are food safe once cured. However, to be able to legally advertise a finish as food safe, you must make a presentation to CPSC proving your claim. This costs a good bit of money and most companies are not willing to do it for the small market of people who insist on such a product. (You are a good example of why it is not worth doing -- even those who want this, like you, are unwilling to pay for it.)
Some companies, such as Behlen and General, have taken the time and money to do so, and can and do advertise their products as food safe, or 'salad bowl finish.' However, any oil based varnish or polyurethane you normally use will work just dandy.
