Re: Dowel Plate?
Dave Mount, NE Minnesota
>Here's the one I made. For a long time I just drilled a hole in whatever piece of steel I had laying around. Truth be told, that worked just fine. But, after seeing the LN version, I decided to make one similar to theirs. It started as 3/16" O1 which I drilled while annealed, then hardened and tempered to peacock color -- that's around 60 Rockwell if memory serves. The holes are from 1/8" to 7/16" by sixteenths. The white oak frame is rabbeted to make the surface of the plate flush and is hollow in the middle to give the pegs a place to fall.
I was going to counterbore the back side 1/64" larger about halfway through to let the pegs pass easier, but I forgot until after it was hardened and tempered, and it would probably be hard to do at that point. The surface appears black in this pic, but it's actually pretty well polished, it's just reflecting darkness from the back of the shop.
Best,
Dave
