Table Router?
Table Router?
Table Router?
>Just Ordered new bearings for my 12-yo Ryobi RE-600. If they solve the issue, I'm GTG.
BUT
If not, I'm looking for a new 3hp VS table router.
Who gotz what that they'd recommend for table use only? I'm NOT going the Jessem route, so it must be a plunger that's fairly easy to adapt for a crank elevator.
Thanks
mm
Re: Table Router?
Re: Table Router?
Tony - Memphis
>I've been real happy with the Hitachi MV12 and a Router Raizer. I removed the springs from the colums and that made it easier to adjust.
Tony
Re: Table Router?
Milwaukee
Re: Table Router?
Re: A Freud 2000e?
Glenn Madsen, SF Bay Area
>That's what I bought, 8 or so years ago. Inexpensive, or so it seemed, at Amazon. Rugged and strong, too big for me handheld, it's been in the table for years. I have a Router Raizer that's never been installed. Never got around to it, or really needed it.
There are intermittent deals on them at Amazon and elsewhere...
Re: Table Router?
Hitachi M12 V, sans springs, handles, etc.
Dave Bair, Eaton Rapids, MI
Re: Table Router?
I second the Hitachi M12 V
Ray Carson - Lawrenceville, NJ
Re: Table Router?
Re: Table Router? *LINK*
Bob Lemon Sacramento Ca.
>Mark, I have two of the Ryobi RE600 routers in tables. Check these links for information on using the router in the table.
http://www.geocities.com/rslemon/dustcollectionforrouter.html
When you replace the bearings, make sure they are sealed high speed bearings. Be careful with the donut on the back end. It's a round magnet that activates the tach on the speed control. Pull and check the brushes before disassembly!
Ultimate router table
Re: Table Router?
Thanks Bob
>I checked with Ryobi Tech and they are black sealed. I'm having a repair guy at a local mill supply shop install them as I don't have either a bearing puller or a press; he does.
Verrrry impressive rig you've got there; way beyond my simple needs for raising and lowering the machine to cut the occasional slot, edge or tenon.
The screeching just started at the end of the job yesterday so I'm hoping that the new bearings will save the day. The router's been bulletproof for better than 12 years, but spinning an 1-1/4" planing bit to cut 1,000 feet worth of 1"x5/8" shiplaps was asking a lot of the Old Girl even in three stage cuts.
mm
