New shop lighting (Long)
John in IN
>I'm finally going to build my own shop, rather that using the local Art Center's woodshop. The existing 2 car garage (vintage 1920, in need of major repairs) will be replaced with a 2 1/2 stall garage with an attached 18'x24' shop. The shop will have a cathedral ceiling sheathed with drywall, and the attic over the garage will be accessed from the shop and used for wood/junk storage. I'm just in the early planning stage and I'm sure I'll have many questions as work progresses. Here's the first: Would recessed, enclosed fluorescents in the ceiling be preferable to hanging fixtures. Although the light would not be direct and changing bulbs would be a pain, if they were recessed they wouldn't be dust collectors and the inevitable buzzing would be dampened. Here's some preliminary drawings, any thoughts? Thanks.
Re: New shop lighting (Long)
steve mackay
>I haven't drywalled the ceiling yet but . . . yes, the hanging fixtures collect MOUNDS of dust. Swing a board over and knock one and your covered. One day . . . sigh.
Tony - Memphis
>I have enclosed fixtures that are attached to he ceiling (not hanging). They seem to work fine. I've been in the shop 10 years and never had to change a bulb! These are the fixtures that fit flush to the ceiling and have a wrap around plastic diffuser.
Enjoy your new place!
Tony
Skylights
Mac in Indy
>With a cathedral ceiling the idea of skylights comes to mind. I'd take advantage of all the natural light you can get in there! I'd probably have at least 2 on each half of the roof with surface mounted florecents. Put in more than you think you need, I have 500 sq ft and illuminate with nine two tube 4' t8 units. I also use a warm spectrum bulbs. I augment with 15+ 75W track lights for task lighting. Use the new electronic ballasts with the T8 bulbs and you will have no hummmmmmmmmm. I also am an advocate of track lighting for task lighting to augment the general Florescent lighting.
Mac
John in IN
>Are your fixtures mounted in a cathedral-type ceiling, at an angle to your work surfaces? Thanks
Re: Skylights
John in IN
>Thanks for your help. I agree with you about the skylights and I have 4 in the plans. But I'm a little reluctant since my last experience years ago with one in our house was not a good one with leaking problems. I'm being assured by the contractor that with the steeper roof pitch and properly flashed, they will be waterproof. Do you think that lights mounted flush with the ceiling (angled to the work surfaces) will be a problem? I'm thinking that if I overcompensate with the number of fixtures that it should not be an issue.
Re: Skylights
Curly Smith
>If you install the fixtures on an angle then you will have plenty of light in the center of the room but the perimeter may need some help. In the center, you'll have overlapping light from fixtures on each side of the ceiling. Each wall, though, will be primarily lit by the fixtures on the opposite ceiling and they're a long way away. You might want to think about some adjustable spotlights or specific task lighting for the perimeter.
Re: Skylights
John in IN
>You have a good point. Thanks
