How to draw an arc?
How to draw an arc?
How to draw an arc?
Brint in Richmond, VA
>I know this is on the web (or website) somewhere, but I can't find it.
I know the length of the chord, and the greatest distance to the outside edge of the curve measured perpendicular from the chord -- how do I either 1) figure out the radius (so I can set up a trammel jig) or, even better, 2) draw the arc without having to build a radius jig / use trammel points (if it can be done)? The curve is fairly shallow, so I'm afraid the jig (radius) would end up being too long to be usable.
Tks --
Re: How to draw an arc?
>Have you considered a "bending curve"? I have some thin slices of hardwood that I've drilled holes in both ends. I've put a string through the holes and tighten it to the desired curve.
Gary Camp, Bend, Oregon
>Given that you know the chord length and height. I would put a nail at each end of the chord, put a mark on the board at the height, take a nice straight grained flexible piece of wood and draw the curve. You could make it easier to draw by adding a 3rd nail at the height of the curve, minus the thickness of your wood. Hook the slat inside the end nails and oustide the height nail. That should be close.
glc
>Brint, there are literally millions of arcs you can draw using dozens of techniques, so its hard to answer your question without knowing more. OTOH, My math skills are not all that strong, so I can't do the math to get exactly what I want, so I do it by eye or trial and error.
Two ways that come to mind are to use a loop of string or two sticks nailed together at an angle.
Drive two nails And wrap a string around them and tie a know in the loop so that it reaches a point that represents the width you want on one side. put a pencil in the loop and draw an ellipse by running the pencil around the two nails as if they were the center of a circle. You will get an ellipse, but its shape will change with the distance between the two nails and the length of the loop. If the nails are close together and the loop is fairly long, you get something close to a circle. The nails far apart and a fairly short loop give you a radical ellipse.
Another way is to use two sticks nailed together at and angle and two nails. You put the pencil in the elbow of the two stick and then with the pencil at one nail you slide the sticks so that an arc is formed while keeping the sticks pressed against the nails. Then you do the mirror image on the other side if you want an ellipse. Norm used this technique a few months ago and said he found the Info on the web. So you might search for Drawing an ellipse or arc. Or search the New Yankee site.
The math way *LINK*
Larry Marker
>The other suggestions are the way I would go, but if you want to do the math route, there is a great calculator at the bottom of the page at this website.
Larry
Circle calculators
Re: How to draw an arc? *LINK*
George Sinos
>In 2006, one of the senior members of the Omaha Woodworkers Guild demonstrated several methods of layout for construction.
A few of the photos near the end of this gallery show the step by step method of laying out an arch with three nails and a couple of boards.
This may give you a few ideas.
See you later, gs
Layout methods for arcs and ovals
>Given the chord length, c, and the height h, the radius is calculated:
r = (c^2+4*h^2)/(8*h)
The page below is the best I've seen for arc calculations for those of us disinclined to derive the formulas each time.
http://mathforum.org/dr.math/faq/faq.circle.segment.html#3
Calvin in Irmo, SC
>Brint,
The formula to calculate your radius is: Radius=((1/2 Chord)�+(Height�))/2H
or in plain English: one-half the chord length squared plus the height squared divided by two times the height.
Thanks, folks --
>The math solutions are just what I need to make a jig with the right radius. And Barry's second explanation looks to be the description of one of the latter techniques on the website George linked me to. I'm kind of slow, and didn't quite understand either one by itself, but after considering the two together I get it (!) That may end up being the technique I try first for this project.
Thanks again to all. WC "rocks"...
