Re: Help! Paint over silicon OT Kinda
Al Stokka - Cambridge, Iowa
>James,
I had a similar problem while refinishing a maple table. Michael Dresdner wrote:
"The solvent for silicone oil is mineral spirits. Scrub contaminated raw wood with liberal amounts of mineral spirits and sop up as much as possible (don't just spread it around.) Follow that with a scrub of liberal amounts of warm water laced with household ammonia, which is a surfactant for silicone oil. Again, mop up as much as possible. This one-two punch will remove the lion's share of the silicone oil."
I questioned Michael's use of "silicone oil." He wrote:
"There are two distinctly different chemicals: silicon (no 'e' on the end) and silicone. The latter, silicone, is an oil. The former is a mineral, and shows up in a compound called silicon carbide commonly used on sandpaper. It is important to make this distinction so people do not fear that the silicon carbide paper will cause silicone contamination (it won't).
Oddly, there is a contamination issue with some interlaced self-lubricated silicon carbide papers, but it has to do with the zinc stearate, a soft, dry soap, and has nothing to do with silicone, though the result of the two contaminations often look similar. Because of that, there is some confusion, and I tried to make things clear so that I would not contribute to that confusion.
Al
