kreg jig question
kreg jig question
kreg jig question
jared
>Hello: I am thinking of buying a kreg jig for attaching face frames to cabitnet carcasses. I have a friend that uses one and he says it works great for that purpose. You can get a rebate on Amazon for it now. I will be attaching hard maple face frames to plywood carcasses. What size of screws do you need for that purpose? There are different lengths and thread pitches available. How long does the special drill bit and drivers last? Is it worthwhile to order spares ahead of time? I kind of live out in the middle of nowhere so I would be mail ordering all of this stuff and would kind of like to know ahead of time what I need to save shipping and delays. Any good advice or comments out there? Thanks ahead of time. Jared
Re: kreg jig question
Dan Donaldson
>If you look at the data for the jig, they define screw lengths for different thicknesses. I believe that 3/4 to 3/4 is 1 1/4 inches. You have to play with the stop collar a bit to get the depth just right and then just start putting them together. The coarse threaded screws are for softwoods and the fine threaded ones are for hardwoods.
Nat Robison
>Everything Dan said is correct. You can also find a ton of info at www.kregtool.com. If you are buying your first jig, I'd go with the one that costs around $40. It will do everything you need. I'm a big fan of pocket screw joinery......it's easy and fast.
Generally speaking, you use 1 1/4" screws for joining 3/4" material and 2 1/2" screws for joining 2x material.
You shouldn't have to pre-order replacement bits......with care it should last a while. Lowe's (at least by me) carries replacement bits, screws, and jigs.
>I agree with all of the above. I use my jig occasionally and have probably driven 2-300 screws. Its at least five years old. I have not needed a new bit or driver. I have a Lowes literally in site of my house and they store my spares for me, but if it was a lot of trouble to get one, I might stock a spare bit and driver.
Dave Bair, Eaton Rapids, MI
>I use a Kreg and pocket screws to attach face frames to plywood cabinet sides, as you propose. I've found that 1�" screws are often too long; the plywood will compress much more than solid wood under the screw's pressure. Try to find some 1" screws or be very careful in adjusting the drill's stop collar. Plan your drilling carefully; the pocket holes will show. The filler pegs sold by Kreg work, but are a pain to level in a cabinet interior and are often not a close match to your hardwood.
Moses Yoder
Moses Yoder
>I suggest always keeping a spare bit handy because the tip can break off of the drill bit. If the tip breaks off you are done drilling pocket holes. If you don't mind having your work interupted a few days while you wait for another bit you don't need a spare bit. We used to break the tips off frequently in production work. I think it was due to misuse by the guys but am not sure. You always want to insert the drill bit into the jig before you start the drill, and then start the drill before the bit is contacting the wood. If you push down against the wood then start the drill I think you will break the tip off the bit.
P. S. PLEASE read the instructions that come with the jig and follow the instructions until you have assembled a few joints. Then feel free to ignore the instructions and experiment.
>I have used over 1000 pocket-hole screws over the years - mostly in pocket holes. I never broke my bit. It did get a bit dull though.
I believe that the bits were abused.
I do agree that a spare bit is good insurance though. If you even dropped the bit on a concrete floor, for example, it could break.
