REAL MILK PAINT
OT Plumbing question
Tom Pilsbury (Chicago)
>The hot water pressure at the bathtub has reduced to little more than a trickle in the past month or so. I'm thinking that the problem is a buildup of crud at the hot faucet because the rest of the house is okay and even the cold water in the tub has full pressure. So what I need to do is take it apart and clean it. The problem is there's no shutoff that I can find. I don't want to remove the stem if there will be pressure behind it. So my question is Can I close the incoming cold water valve to the hot water heater and stop the flow of water to all the hot faucets in the house? (There is no valve on the outgoing hot line)
Re: OT Plumbing question
Jason Roehl in Lafayette, IN
In a word...
>...yes. You can shut off the water to the water heater, open the hot valve on a sink or two, and you will be good to go.
Jason
Re: In a word...
>If your water heater is electric you might want to turn off the power to it, just in case it drains down below the level of the top element. (unlikely)
Some tub valves have shut offs hidden behind the cover plate or Escutcheon on the tub side that you turn off and on with a screwdriver.
Some hot water valves have a temperature sensor built into hem to prevent scalding. (Only a few years old) If you have one of those, you may be having trouble with that part of it.
No problem...
>I'm actually surfing the web and drinking beer right now instead of doing a couple plumbing items I just bought parts for this afternoon. I have a drain line to repair (finally traced a long-time leak back to it this morning), and since I have that section of wall open, I can put in a new sillcock for exterior use--the current one is missing its handle (odd size/shape, can't find a replacement, it was that way when I moved in last year).
I guess 4 minutes is a pretty quick response. Right place, right time for once!
Jason
Make sure you....
>.... turn off the water heater first.
Happy Woodworking!
Personaly . . .
steve mackay
>I always shut it off at the meter. Mine is out by the street. I'd be concerned about not finding a shut-off though. Hmmmmmmmmm. But, thats just Mr. " What-if " talking.
Sometimes not
Larry Marker
>I have had a long standing problem in my house where turning off the cold water feed to the water heater did NOT keep water from flowing vigorously from a hot water faucet. I finally fund the culprit -- the one-knob faucet in our master bath shower was leaking water across the mixer such that if there was no water pressure coming into the hot water side of the faucet, the cold water would flow across the mixer and presurize the hot water line.
Larry
As a side comment. When I had the water softener
on Henthorn
>installed in the house in Texas, I had the installer put in 3/4" ball valve in the garage so I could turn the water off quickly without having to go out to the meter at the curb.
walt cheever
>AND, I'd leave a faucet open that is located below the one you are working on to bleed off any pressure that might build up due to leaking valve(s).
Steven Antonucci
Common sense: Turn whatever valve off...
steve antonucci
>and then try the hot water at the place you intend to work!
I never assume that my shutoffs work, so I'll usually kill the main (crawl space) and open up the faucet to drain any remaining water. After a few minutes, there shouldn't be any dripping. If there is, something isn't right with your shut-off valve.
Steven
Dreading a dripping faucet and running toilet repair...
del schisler
>sound's like a moen You can take it out You may need a puller Their is a brass clip that holds it in their If it is moen If not than a big nut holds it If moen you can take the plastic end off and take the ball bearing out and clean the lime off and clean the inside also My let it soak in some lime remover The little bearing has to be able to move back and forth for the unit to work When you get it out shake it and i bet you wont here the bearing rocking back and forth ? also get some grease It is in the plumbing dept. In a gray can It is made for that use
